cargo light (trunk light) doesnt turn on..
Old Mar 9, 2003 | 07:44 PM
weakGOODJunKieS.com's Avatar
Default cargo light (trunk light) doesnt turn on..
i tried changing the bulb and turning on my headlights, it still doesnt work. could it be the fuse? and if so waht kind of fuse woudl i need?
Old Mar 9, 2003 | 07:50 PM
Vu's Avatar
Vu
Default Re: cargo light (trunk light) doesnt turn on.. (98-DC2)
You're not the only one. Mines a 98, and till this day I still haven't found out what's the problem .
Old Mar 9, 2003 | 08:02 PM
BIGGIDYBOB's Avatar
Default Re: cargo light (Vu)
same here
Old Mar 9, 2003 | 08:33 PM
ragejed's Avatar
Default Re: cargo light (BIGGIDYBOB)
lol, is it plugs in? behind the panels?
Old Mar 9, 2003 | 09:10 PM
Default Re: cargo light (ragejed)
yea mine was plugged in all the way, i took it off and put it back in to make sure it was in.
Old Mar 9, 2003 | 09:12 PM
rodrez.'s Avatar
Default Re: cargo light (98-DC2)
Probably the best thing to do is borrow a friends light, swap it with yours to find out if it's the actual light itself, or a wiring problem.
Old Mar 9, 2003 | 10:57 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
same here, I'm thinking it might be the switch on the trunk latch, but I've been too lazy to check.
Old Mar 9, 2003 | 10:59 PM
MTK Kommander's Avatar
Default Re: cargo light (PatrickGSR94)
my integ was like that too.. it would come on sometimes.. and sometimes it wouldnt..
Old Mar 10, 2003 | 10:54 AM
Default Re: cargo light (MTK Kommander)
sounds like a genetic problem with all integs.... someone should contact acura about this...
Old Mar 10, 2003 | 01:22 PM
crxforum's Avatar
I had the same problem in my CRX. I replaced the bilb, fuse and had the whole thing apart. Nothing worked. I tested the bulb and it was fine. You know what the problem was? The solder holding on the positive connection was cracked. I couldnt see it because it was cracked on the bottom and not the top. I removed all the solder and replaced it with new solder and it works like a charm. Maybe you should try that. But I think that mine was replaced one time down the road before I got it.
CRX Forum
Old Mar 10, 2003 | 03:03 PM
SSBlueDC2's Avatar
Default Re: cargo light (crxforum)
Same thing happened to me in my teg. I still can't figure out what's wrong.
The-Kid
Dec 19, 2016 11:38 AM
sky9
May 26, 2010 12:36 PM
civickid03
Jan 23, 2008 11:37 AM
JDubya
Mar 13, 2003 07:44 PM
