lowering springs????
Old Mar 9, 2003 | 07:00 PM
Phat_GSR's Avatar
Default lowering springs????
does anyone know if h&r springs from a 99 civic will lower my 89 crx??? will they fit and will they lower it at least 1.75 inches to 2.5 inches???
Old Mar 9, 2003 | 07:47 PM
Phat_GSR's Avatar
Default Re: lowering springs???? (Phat_GSR)
up
Old Mar 9, 2003 | 07:48 PM
monkeypee's Avatar
yes they will fit but i have no idea how much they will lower it
Old Mar 9, 2003 | 08:04 PM
Phat_GSR's Avatar
Default Re: lowering springs???? (monkeypee)
thanks monkeypee now im one step closer to buying them, anyone have a rought idea how much tehy will lower it??/
Old Mar 9, 2003 | 08:36 PM
SC0TT's Avatar
Are they OE, Sport, or Race springs? Either way, the spring rate will be stiffer.
[Modified by cr-tegra, 5:36 AM 3/10/2003]
Old Mar 9, 2003 | 09:09 PM
FullMetalJacket's Avatar
Default Re: lowering springs???? (cr-tegra)
i dont know if they will fit on the spring perches perfectly..my 95's would fit nice on my 88 so i ditched them..ur front may be a lil higher since the struts and springs are lil taller on the newer civics
Old Mar 9, 2003 | 09:17 PM
EG8R's Avatar
WTF No they won't work. They are different lengths....
Old Mar 10, 2003 | 02:10 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: lowering springs???? (mr. skelly)
essentially they will fit, why do you think they have 88-00 coilovers and etc.
The thing is the lowering will be different because the weight of the car is different.
Old Mar 10, 2003 | 05:59 AM
Rob!'s Avatar
Default Re: lowering springs???? (MugenHonda)
this is true...if you sit on your car somewhere your car will lower more...which is the same thing as having a heavier car...if the springs were on a heavier car and you put them on an ef then the car will sit higher because the ef is so light
Old Mar 10, 2003 | 08:03 PM
Default Re: lowering springs???? (RaceFacer)
Could that be why my 88std with ac sits a inch lower than when i had teh same springs on my 89 crx without a/c????My crx front sits higher front and hb is getting teh dragster looks..both didnt have blown struts
96ej8MR
Suspension & Brakes
Apr 22, 2007 02:23 PM
zerogravitycrx
Nov 1, 2004 11:51 PM
Tommy1223
Sep 24, 2004 04:56 AM
JDMCRX
May 8, 2004 09:30 PM
