car wont rev up
Old Mar 9, 2003 | 06:52 PM
monkeypee's Avatar
Default car wont rev up
i have a 91 civic dx, i finally got the car to start and idle but it wont rev up when the throttle is turned. it did rev up a couple times but it would sputter and die when it did, every other time it wouldnt do anything. Sometimes it idles fine and other times the RPM's rise and fall and then it will stay constant for a while and then go back to rising and falling. It's not throwing any codes and i put new gas into it, so could this maybe be the fuel filter? if not what could it be?
Old Mar 14, 2003 | 10:08 AM
4gnhatch's Avatar
Default Re: car wont rev up (monkeypee)
you might want to put a gas treatment in it and let it run for awhile then try to rev it up! good luck and hope this works!
Old Mar 29, 2003 | 07:47 PM
R@mon's Avatar
Default Re: car wont rev up (4gnhatch)
bump, im having the same problem.
Old Mar 29, 2003 | 11:01 PM
Stupid Ass's Avatar
Default Re: car wont rev up (93h22a4)
Check your timing, if its good then let me know... Ill help ya out till' the problem is fixed.
Old Mar 30, 2003 | 06:46 AM
R@mon's Avatar
Default Re: car wont rev up (SOHC NoTEC)
i dont think his problem would be timing, because i checked my timing(both ignition and cam/crank timing) and its dead on and it still does what he says. im starting to think its electrical because when i first start the car it will rev normal but once the ecu does all its checks the car wont rev, and the only code its throwing is a code 22 which is the vtec pressure switch? i dont get it...
z7rix
Oct 10, 2013 11:40 AM
yeah_its_boosted
Jan 10, 2006 03:31 PM
4glude
Oct 21, 2003 08:48 AM
monkeypee
Mar 10, 2003 08:42 AM
Sirvtec
Feb 10, 2002 03:21 PM
