Can someone help me figure this out...
Old Mar 9, 2003 | 05:12 PM
brimy311's Avatar
Default Can someone help me figure this out...
i have an 87' honda accord and since it started to get cold out, the battery will drain after one night of sitting...for a while i could get away with pulling the PGMFI fuse, but after letting it sit for a week it is dead anyways the alternator is working and the battery is new....anyone have this problem?
tia,
Old Mar 9, 2003 | 05:25 PM
ratherbewalking's Avatar
Default Re: Can someone help me figure this out... (brimy311)
are you sure its not your starter? and i think there is a thingy to hookup to your car that can tell if power is being drained while your car is off... mabey a voltmeter will work... i dunno
Old Mar 9, 2003 | 05:59 PM
scrubachu's Avatar
Default Re: Can someone help me figure this out... (ratherbewalking)
battery could be dying. had the same problem when my eclipse was cold. car wouldnt start, but when it was warm, it would start ok. the water was low on my battery. changed the battery and it was good to go. check the battery with a volt meter. then jump the car if you have to, and remove the negative terinal. the car should run off the alternator. it it dies, check the alternator.
Old Mar 9, 2003 | 06:50 PM
97accordex's Avatar
Does that model year have the pop up headlights?
Make sure that the headlights are all the way down and that the electric headlight motor is not draining the battery. It will try to shut if it does not sense that it is closed and drain the battery.
Old Mar 9, 2003 | 07:03 PM
krzyaccord's Avatar
Default Re: Can someone help me figure this out... (97accordex)
Hook up a Vat 40 and check parastactic drain.
Old Mar 10, 2003 | 07:06 AM
brimy311's Avatar
Default Re: Can someone help me figure this out... (krzyaccord)
hmmm, well the battery is brand new...i have pop up head lights but pulled the fuse to keep them up along time ago. the alternator is also brand new and working. thanks for the help i guess will fart around with it somemore with volts meter..
Old Mar 10, 2003 | 01:39 PM
JPX's Avatar
JPX
Sounds like a ground loop issue.. All the hondas from 84-2000 have multiple gnds throughout hte car especially at the nose..acura fixed That back in the early 90's (~92)
I would remove the Alarm system and eliminate and unify the grounds throuhout the car...
(Best bet)
Old Mar 10, 2003 | 03:23 PM
brimy311's Avatar
Default Re: Can someone help me figure this out... (JPX)
so if one of the grounds are not grounding then it would cause this problem?
Touek
Oct 21, 2011 03:20 AM
Nick6
Aug 18, 2010 05:26 PM
Si_eg6
Jul 14, 2008 02:47 PM
tigueremalo
Jan 22, 2007 03:10 PM
deviant94ex
Apr 27, 2003 11:17 AM
