need some help on gsr complete swap into 93 delsol
i want to know wat do i need when i do a complete gsr swap into my 93 delsol. it comes with everything such as ecu, trans, motor etc..... wat do i need to do, since i got a complete do i just put in the motor and connect all the vacuum and sensor and plug the ecu wires or there is more. some help would be great or pics. thanks
i put a GSR into my 95 hatchback, i used everything from the GSR(engine, ecu, axles, linkage). i think i used an older integra rad hose that i found at the wrecker, plus another coolant line didnt line up right. other then that you have to run 4 wires for the VTEC from the engine harness to the ECU, which is really simple to do. make sure you get all the mounts and brackets from the GSR. The exhaust didnt line up right on my hatch it had to be extended about 4 inches but i heard that if you order a Header from an SiR(Si in the US) it will bolt right up or in your case if you get one from a Del Sol with DOHC it should bolt right up..
aite guys thanks alot. was just making sure is it easy to do or not. cuz i never done it before. i did some electrical stuff n bolts on but no swap
bh2285
Jun 20, 2004 12:34 AM
