Okay, Final Post about headgasket to confirm. With Pics!!
Old Mar 9, 2003 | 03:50 PM
MikeMAN's Avatar
Default Okay, Final Post about headgasket to confirm. With Pics!!
Any help to confirm this as a headgasket problem, lemme know!
Thanks again guys!,
mike
Old Mar 9, 2003 | 04:00 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Okay, Final Post about headgasket to confirm. With Pics!! (MikeMAN)
i can't really make out what u are trying to show in those pics, but check your oil if it looks like a chocale mike shake or u see radiator fluid in the oit then u have a blown head gasket
Old Mar 9, 2003 | 04:13 PM
navin's Avatar
Default Re: Okay, Final Post about headgasket to confirm. With Pics!! (streetdreams02)
Remove your oil cap - there should be milky white crap on it if there is a blown headgasket...
Old Mar 9, 2003 | 04:53 PM
Chiovnidca's Avatar
A leakdown test is a good way to confirm a blown head gasket.
Old Mar 9, 2003 | 05:30 PM
MikeMAN's Avatar
i am just showing the oily mess in my engine and my brown coolant, and then the oil that is on the front of the block.
mike
Old Mar 9, 2003 | 06:11 PM
MikeMAN's Avatar
i guess my biggest worry is can anyone explain why it isn't idleing without killing? if i use the powersteering(i.e. turn) or use any electronics is bogs so my engine is really weak. there is also white smoke that comes out of the exhaust and the exhaust tip is kinda oily.
mike
Old Mar 9, 2003 | 10:03 PM
MikeMAN's Avatar
i just had a thought, is this maybe oil coming from the turbo charger, getting into my charge lines and being blown through the engine?
thanks,
mike
p.s. i am stranded 1.5hrs away from school right now, my car won't start and I don't feel like having to replace the starter in addition to whatever might be causing this.
Old Mar 10, 2003 | 06:28 AM
MikeMAN's Avatar
anyone?
Mike
Old Mar 10, 2003 | 07:23 AM
Russ713's Avatar
dAng!
with the missing coolant, i'd vote for head gasket.
Old Mar 10, 2003 | 09:22 AM
joshwhe's Avatar
from looking at the pics i would say idle is bad.. prob cuz coolent is getting in your cyl's thats what the white smoke is from too...... chances are its your headgasket....
Old Mar 10, 2003 | 11:27 AM
baonest1's Avatar
Default Re: Okay, Final Post about headgasket to confirm. With Pics!! (joshwhe)
or compression test..
usdmEHboy
Mar 21, 2010 06:36 PM
Hill4589
Nov 4, 2009 07:21 PM
opiumdaze
Jan 24, 2007 09:19 AM
AdoRe
May 15, 2005 10:23 AM
sohcvtec1995
24
Feb 29, 2004 07:00 PM
