where can i find codes??
Old Mar 9, 2003 | 01:12 PM
sir2chad's Avatar
Default where can i find codes??
my check engine light comes on when it kicks into vtec...i checked the code and its throwing 22...where can i find out what this is??
Old Mar 9, 2003 | 01:19 PM
Chiovnidca's Avatar
Default Re: where can i find codes?? (sir2chad)
Code 22 = VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch.
If your oil level is full, check the presure switch with an ohm meter. There should be continuity with the engine off.
Old Mar 9, 2003 | 01:27 PM
sir2chad's Avatar
Default Re: where can i find codes?? (D16Chiovnidca)
mucho thanks...i got a JDM b16a that didnt have a vtec oil pressure gauge...so i had to ground one wire to the thermostat ground and connected to other wire my vtec solinoid...that wire must have came lose...thanks bro...
where can i get a list of what different codes mean...if i where to have another code??
Old Mar 9, 2003 | 01:34 PM
Chiovnidca's Avatar
http://tech.hybridgarage.com/tech/codes.html
Old Mar 9, 2003 | 01:45 PM
sir2chad's Avatar
looks good...thanks man
racereaper7
Aug 14, 2007 08:56 AM
whophlungpoo
10
Oct 1, 2006 10:52 AM
hondacurab16
Sep 21, 2005 11:00 PM
drudy
Aug 26, 2005 12:20 PM
maggsgsr
Apr 20, 2004 02:37 PM
