Will a GSR stock shifter fit in a crx?
Old Mar 9, 2003 | 01:04 PM
headhunter's Avatar
Default Will a GSR stock shifter fit in a crx?
i'm running the b-series hasport shift linkage for the EF. Will a stock gsr shifter fit on the shift linkage? I am planning to purchase one and was wondering if there will be any fitment issues. Most of the shifters from the civic/integra on up i know should fit but wasn't sure if the GSR model was any different.
Old Mar 9, 2003 | 01:33 PM
stingray2772's Avatar
Default Re: Will a GSR stock shifter fit in a crx? (bbcrx)
im pretty sure actually any teg will work except gsr
Old Mar 9, 2003 | 01:39 PM
jdm169's Avatar
Default Re: Will a GSR stock shifter fit in a crx? (stingray2772)
i posted a topic on this as well (search) you'll probably have to grind base of the shifter to fit in the linkage because it is too wide. The short shifters made to fit a gsr would fit because they make them smaller with spacers if you need them. So with some modification it will fit...hopefully
rivoe302er
Dec 24, 2009 03:48 PM
pnk_03
Mar 17, 2008 08:58 PM
90da4dr
Dec 24, 2002 04:15 PM
haloseven
Dec 11, 2002 07:32 PM
GapxGuy
Oct 4, 2002 05:14 PM
