problem with installation of type r replica strut on my ls...
Old Mar 9, 2003 | 12:03 PM
weakGOODJunKieS.com's Avatar
Default problem with installation of type r replica strut on my ls...
i dont have those 4 bolts like the gsr does.. what kind of bolts do i need?
here is what i mean.
posted in tech, but i think i will get better response in heere.
edit- asked mod to move this to integra forum. sorry
[Modified by 98-DC2, 9:04 PM 3/9/2003]
Old Mar 9, 2003 | 12:43 PM
splitime's Avatar
Default Re: problem with installation of type r replica strut on my ls... (98-DC2)
Just get some 5/16ths(i think, you can take the bar and ensure the bolts fit through), washers and a couple nuts. What i did was drop a washer onto the bolt, push it into the engine area from the wheel well. Then dropped the bar onto it, added another washer and tightened the nut onto the bolt. Nice and easy. If you get a bolt thats really long you can also always trim it down.
Old Mar 9, 2003 | 01:53 PM
Default Re: problem with installation of type r replica strut on my ls... (splitime)
do you mean, push the bolt from under the wheel well into the engine area? i bought a 5/16 rod bolt, i thought it would have just screwed in but it doesnt. do you think i should cut it and buy 4 more nuts? or should i return it and get 4 normal 5/16 bolts
Old Mar 9, 2003 | 02:05 PM
splitime's Avatar
It will not actually screw into the chassis, i believe the bolts on the ITR is actually tack welded. You'll have to push the bolt from under the well area into the engine area as you mention, then use a nut on the bolt to tighten it down onto the strut bar. I just used 4 2in(i think) 5/16th bolts and 2 washers per bolt( in wheel well, and above strut bar) then 4 nuts to tighten those up. I might have actually used 2 nuts per bolt though to get a locknut effect.
Old Mar 9, 2003 | 02:34 PM
thanks, i just bought 4x 5/16 bolts 8x washers, and 4x 5/16 nuts. im going to install it sometime this week thanks for ur help.
95LStizzy
Oct 25, 2006 03:30 PM
Takumi Fujiwara
Dec 22, 2005 08:44 AM
Aaron M
Dec 9, 2002 10:12 AM
satintegra
Jun 12, 2002 07:44 AM
SPiFF
Jul 3, 2001 03:37 AM
