Help VSS wiring!!!!!!!!!!!!!!!
Old Mar 9, 2003 | 10:48 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default Help VSS wiring!!!!!!!!!!!!!!!
I swapped my cluster for a GSR everything is working except for the speedometer, I need to know excatly how to run the wires from th VSS, I know the yellow with the white is 12v power. the yellow with the blue is vss.
Could someone tell me excatly how to do this
step by step.
[Modified by MR.RED'89, 11:49 AM 3/9/2003]
Old Mar 9, 2003 | 12:09 PM
ghettocrxsi's Avatar
Default Re: Help VSS wiring!!!!!!!!!!!!!!! (MR.RED'89)
If you are looking at the the clip there are 3 wires. Also there is the button to release the clip from the vss. Have the button facing away from you and it goes.
Power,signal,ground
look at this diagram its from a 92-95 civic it shows you everything you need to know about on testing and working with vss
http://www.honda.co.uk/owner/CivicMa...df/23-a120.pdf
Old Mar 9, 2003 | 01:37 PM
^Sammy]!.'s Avatar
Default Re: Help VSS wiring!!!!!!!!!!!!!!! (ghettocrxsi)
Okay where does the white/yellow 12v wire, and where does the yellow/blue VSS wires connect to............do i connect the yellow/blue wire to the orange wire on the GSR harness and then also run a wire from the same connection to the ecu?
how bout the yellow/white wire which switch power does it connect to?
please help ASAP
Old Feb 12, 2005 | 05:52 PM
HamiltonRex's Avatar
Im having a similar problem..
Sensor is wired right. No speedo.. Ill test it tonight, better be the sensor not the cluster
Old Feb 12, 2005 | 08:04 PM
tc_gts's Avatar
15amp fuse on the 12volt power source...
ground it to the thermostat housing if possible
and the signal goes to the ecu b16 aswell as the cluster...
okie dokie i wired a jdm sir cluster and thats how i did it
Old Feb 12, 2005 | 09:37 PM
HatchBox's Avatar
Skoobie no more...
edit: this is from 03 holy hell....
Modified by HatchBox at 1:47 AM 2/13/2005
Old Feb 12, 2005 | 09:53 PM
^Sammy]!.'s Avatar
WOW this was brought back from the DEAD
simplypinoyy
Jul 13, 2008 03:23 PM
xpionage2
Mar 14, 2007 08:43 PM
HamiltonRex
Feb 13, 2005 06:29 PM
hondaZvic
Apr 22, 2004 12:51 PM
CTRwannaB
Dec 6, 2003 04:52 PM
