pitch alloys
what pitch alloys do i need for a del sol i have been offerd a set off 14x6 honda civic alloys (fit 97-2001civic)with a pitch circle diameter of 113mm dont want to buy them and put tyres on them to find out they dont fit HELP
are you referring to offset? the del sol wheels are 14" by 5", same as the american crx si, if i am not mistaken. (350mm by 125mm.) the offset on both wheels should be 45, not sure of units of measurement. this is the distance between the backside of the mounting location and the centerline of the wheel. almost all honda's use 45. i mostly see 185/60/R14 sized tires on 14 inch wheels.
also, there is the lug pattern to confirm. almost all 4 lug honda's use a 4 by 100 pattern. this is the spacing in between the lugs themselves. accord's are 4 by 114, as are the type r's. the del sol is a 4 by 100, and will work on any other civic/ crx.
SomeGoodBud2
Feb 15, 2007 06:00 PM
ek_slut
Mar 1, 2006 09:27 PM
Drmcdave
Jan 25, 2005 05:39 PM
