My Dyno results: CarTek Tuning South FL Dyno Day
Old Mar 8, 2003 | 11:27 PM
M.A.R.C.'s Avatar
Default My Dyno results: CarTek Tuning South FL Dyno Day
Well... I wasn't going to dyno at first but I was like oh what the hell. Got there after work around 5pm... was gonna dyno only at 6psi (blah). Then since I was waiting on the other cars I said hrm... lemme put back in the turboxs mbc and see if I can get it to stay around 8psi. Did a few runs... held about right. Got on the dyno, first and second runs at runs @ 8psi yielded 179.5whp/155.7tq and 187.4whp/157.3tq. On the 3rd run Stephan convinced me to turn the boost up a little so I turned it up to about 8.5-9psi... netted 191.2whp/159.8tq. Final run I turned it up just a notch more to hold 9psi fully... 193.7whp/164.3tq @ 9psi. Throughout all the pulls I kept a very flat a/f curve somewhere around 11:1. The setup was a T3 60 trim turbo, afc hack, dsm 450cc injectors, turboxs mbc, stock timing.
Here is the dyno sheet
and vids
http://www.tiora.net/~civicryda2k/vi...80whp@8psi.avi
http://www.tiora.net/~civicryda2k/vi...87whp@8psi.avi
http://www.tiora.net/~civicryda2k/vi...whp@8.5psi.avi
http://www.tiora.net/~civicryda2k/vi...93whp@9psi.avi
Thanks to Stephan and Trevor and everyone else from Cartek
EDIT: vid links changed hehe SHOULD work now
[Modified by CivicRyda2k, 2:24 PM 3/9/2003]
Old Mar 8, 2003 | 11:31 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (CivicRyda2k)
Your torque curve looks really good.
Old Mar 8, 2003 | 11:49 PM
I Like Boost's Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (Arturbo)
I was there with the black integra, props for the custom kit. You mentioned you were only expecting 180 whp, pretty good #'s to bad i left before you installed the mbc.
Old Mar 9, 2003 | 12:08 AM
CalvitoSol's Avatar
on what motor is this? how's the spool up w/ your turbo?
Old Mar 9, 2003 | 12:35 AM
Broken Gearbox's Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (theory48)
D16Y8
..nice numbers ..the vids arent werkin
Old Mar 9, 2003 | 07:20 AM
M.A.R.C.'s Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (IMPULSE B18C-T)
aahh ok so UR IMPULSE B18C-T hehehe nice meetin yah man. thanks for the props. I heard ur car was laying down some great numbers as well. Good to finally meet some local H-T peeps as well. The mbc thing was just like an impulse (no pun intended)... I was like... wtf... don't make sense to dyno at only 6psi when i have that sitting in my car! Then Stephan peer pressured me into going up to 9... i was aiming for 10psi but oh well I'm happy with what it did. Still has a fat a/f curve also.
The turbo is a T3 .60 a/r, 60 trim compressor with a .48 a/r turbine on a stock internal D16Y8. Running off the wastegate the turbo spools up 6psi by like 4k. with the manual boost controller... pretty much 7-9psi spools up by like 3-4k.
For the vids you need to download the DiVX codec at http://www.divx.com. If it doesn't work still let me know ill try another format to encode in.
Old Mar 9, 2003 | 07:24 AM
BoostedED9's Avatar
lookin good man.. i wish i could of made it down there...
Old Mar 9, 2003 | 07:30 AM
KevronsEG's Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (BoostedED9)
Sorry no vids still
Old Mar 9, 2003 | 07:51 AM
M.A.R.C.'s Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (CIV616)
ah ok i will try a different codec when i get home
Old Mar 9, 2003 | 08:33 AM
M.A.R.C.'s Avatar
hehehhe now i'm only like 109whp away from you!!!! weeeeeeeeeee!!! that's a whole d16y8 away hehe.
Old Mar 9, 2003 | 08:36 AM
SiRkid's Avatar
vids no work.
exceed bandwidth?
nice though
Old Mar 9, 2003 | 09:02 AM
BoostedED9's Avatar
[Modified by BoostedED9, 1:03 PM 3/9/2003]
Old Mar 9, 2003 | 09:03 AM
BoostedED9's Avatar
it takes time, but im sure that you can do it if you really wanted to..[
Old Mar 9, 2003 | 09:09 AM
dirtySOHC's's Avatar
a few ppl have been puttin up some good numbers w/ the Y8. it makes me more excited as i get closer to putting my turbo on.
BOOST ? ...........................i'll see you next week.
Old Mar 9, 2003 | 09:50 AM
CalvitoSol's Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (dirtySOHC's)
wow, they are really good numbers. much props
Old Mar 9, 2003 | 09:56 AM
sharkcohen's Avatar
Awesome a/f curve
Old Mar 9, 2003 | 10:32 AM
M.A.R.C.'s Avatar
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (sharkcohen)
thanks for the props guys... i updated the links on the videos... they work now
Old Mar 9, 2003 | 10:52 AM
Midwestrider's Avatar
Good #'s Marc.
Old Mar 9, 2003 | 11:31 AM
liam821's Avatar
25 Year Member
i want to hump your car...
liam
Old Mar 9, 2003 | 12:33 PM
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (liam821)
cool vids!!....love the sound of the Type S
Old Mar 9, 2003 | 12:38 PM
VaporTrail's Avatar
New User
nice numbers, wrong dyno
Old Mar 9, 2003 | 12:52 PM
M.A.R.C.'s Avatar
liam
if ya let me hump urs
yah for some reason mine doesn't sound like most my friend's type-s's even if i adjust it.
hehehehe John. I love your dyno too and remember it was still ur settings I've been using on the afc since that time i went up there in early november and dynoed at 5-6psi. Thanks John
Old Mar 9, 2003 | 01:36 PM
93dx--hatch's Avatar
what was your vafc set at?
Old Mar 9, 2003 | 02:11 PM
TurboJesse
Guest
Posts: n/a
Default Re: My Dyno results: CarTek Tuning South FL Dyno Day (93dx--hatch)
Nice numbers marc
Old Mar 9, 2003 | 03:28 PM
M.A.R.C.'s Avatar
thanks again folks...
jesse just wait till you go boost
this is how my vafc is set
Lo
1000……..……..… -45%
2000……..……..… -45%
3000……..……..… -41%
3500……..……..… -40%
4000……..……..… -42%
4500……..……..… -43%
5000……..……..… -43%
5500……..……..… -43%
Hi
5400……..……..… -43%
5700……..……..… -40%
6000……..……..… -43%
6300……..……..… -43%
6600……..……..… -44%
6900……..……..… -44%
7200……..……..… -44%
7500……..……..… -44%
VTEC Crossover Point
5200 H->L
5300 L->H
Throttle Crossover
74% | 75%
These settings flattened the a/f curve on my car when I dynoed @ 5-6psi w/ stock cat back in November. Same settings yeilded the flat a/f u see in the dyno from yesterday.
S@nt0s
Jun 19, 2006 07:48 PM
SpeedDreamz.com
Jan 15, 2004 08:27 PM
xstalkrx
Mar 18, 2003 01:55 PM
