cel code 3 showed up today
Old Mar 8, 2003 | 10:03 PM
badnan's Avatar
Default cel code 3 showed up today
last night my friend and i went out and decided to kill my already dead tires. we found an empty mall parking lot and were doing powerslides using the ebrake. well everythign was dandy till after the 3rd slide, the car stalled and when i turned it on again i had a cel. checked it and its cel 3, map sensor.
checked all connections and everything seems to be fine. doubt there was any damage done since all i did was 3 180 turns, ive done worse during autox.
any idea what could be the problem? you guys dont think that powersliding messed up the map sensor by any chance?
tomorow im going to check all the wires again and reset the ecu, hopefully it will go away. but if not any suggestions or ideas?
thanks
also could i have some how shook the cai so hard that it kinda slipped off? would that trigger the cel 3?
Old Mar 11, 2003 | 01:42 PM
badnan's Avatar
Default Re: cel code 3 showed up today (badnan)
well i checked and all the hoses and wires are plugged in right. reset the ecu and im sill getting the cel. anyone know what to do?
that light is very annoying
Old Mar 12, 2003 | 04:46 AM
JimBlake's Avatar
... its cel 3, map sensor...
Maybe its actually your MAP sensor?
Old Mar 12, 2003 | 04:47 AM
1bad-eg's Avatar
Default Re: cel code 3 showed up today (JimBlake)
Yeah check into it. Sounds like your map took a ****.
mortificationrock
Aug 18, 2010 08:22 PM
justseeingifitistaken
Nov 22, 2006 06:21 PM
liquidxEG
Feb 22, 2005 03:46 PM
B00ST2nR
Apr 18, 2003 03:35 PM
