Need switched power...
Old Mar 8, 2003 | 08:25 PM
R0476's Avatar
Default Need switched power...
I'm hooking up a shift light to my car and I'm just wondering when you splice into a switched power source is it just like splicing any other wire? Can I use one of those wire splicing clips that just clip onto the other wire and you clamp it shut?
I've got the tach signal and ground, jusy need the power. Thanks.
Old Mar 8, 2003 | 08:51 PM
civicrtype's Avatar
Default Re: Need switched power... (R0476)
Dont use those wire taps they tend to come loose, if u can solder the wire, if not splice it and use a pin to make a whole in the btw the wire strands and slip the new wire in and tap as usually. Will never come out this way.
Old Mar 8, 2003 | 08:54 PM
civicrtype's Avatar
Default Re: Need switched power... (civicrtype)
oh ya and I would use an tap on an ACCESSORY or IGNITION wire if you're tappin it to 12v CONSTANT dont forget to use a FUSE.
hondalove323
Honda Civic (2001 - 2005)
16
Jul 16, 2008 12:01 AM
Gibson5469
Mar 18, 2007 05:45 PM
buzzsawstan
Jun 30, 2004 09:09 PM
JOMO_
Audio / Security / Video
Jul 3, 2003 11:22 AM
vtec94
Feb 14, 2003 01:57 AM
