*will 99-00 rear disc brakes bolt up to a 88 crx si?*
Old Mar 8, 2003 | 07:17 PM
JSJ EG6's Avatar
Default *will 99-00 rear disc brakes bolt up to a 88 crx si?*
will 99-00 rear civic si disc brakes bolt up to a 88 crx si?cuz i seen a itr 5 lug on a crx and the si and itr trailing arms shold be the same right???thanks
Old Mar 8, 2003 | 10:35 PM
Jaker's Avatar
Default Re: *will 99-00 rear disc brakes bolt up to a 88 crx si?* (TEAM JSJ)
Yes they will fit. The easiest way for me is to unbolt the hub that holds the caliper from the trailing arm, and swap them around. That way you keep your alignement, and your trailing arm.
Old Mar 9, 2003 | 12:03 AM
JSJ EG6's Avatar
Old Mar 9, 2003 | 07:46 PM
JSJ EG6's Avatar
ttt
boomersz
Jul 15, 2007 07:38 AM
818SpoonITR
Nov 1, 2006 12:06 PM
Snailed EF
Oct 19, 2006 07:43 AM
xoutlawz00x
Sep 20, 2005 01:07 PM
happyclown_69
Mar 12, 2002 08:21 AM
