Dyno of 2.0 GSR @ 10psi
Old Mar 8, 2003 | 03:59 PM
Tofurky's Avatar
Default Dyno of 2.0 GSR @ 10psi
note: it's not a dragIII kit(it's actually mostle maxrev stuff), and the boost is at 10 psi
pretty damn smooth, and good numbers for only 10 psi with a CAT. Would've done more, but the MSD GM 3Bar map sensor didn't want to work with hondata. So this was on the stock map sensor.
All I have to say is holy ****. It pulls pretty damn hard. Without the BFG DR's, I don't get anywhere.
I'm going back in a couple of months, with a working GM 3bar MAP sensor, straight pipe, & Edelbrock IM. And up the boost a wee bit.
Note that this is completely daily driven, in a 92 cx. And was tuned conservatively for 91 octane, and Jeff knows I can't afford to blow something up anymore. Haha. I'll post the set up when I get back.
Old Mar 8, 2003 | 04:01 PM
b18CT's Avatar
Default Re: Dyno of 2.0 GSR @ 10psi (Ruckus138)
what size is your cat?stock?
Old Mar 8, 2003 | 04:25 PM
SiBirdie's Avatar
what u mean everything else stock ? It say IB 2litter, so I assume its a 81mm bore to 84mm. So how can u run on stock piston ? Not to bash on you or anything But I seen normal gsr make more power then that. But either way you got turbo so to you.
Old Mar 8, 2003 | 04:40 PM
InfamousRS's Avatar
Default Re: Dyno of 2.0 GSR @ 10psi (SiBirdie)
seems kinda low for a 2.0 gsr at 10psi...
Old Mar 8, 2003 | 04:51 PM
hybrid901's Avatar
Default Re: Dyno of 2.0 GSR @ 10psi (InfamousRS)
torque seems very very low
Old Mar 8, 2003 | 04:58 PM
ekb18c's Avatar
Those numbers seem about right.
Old Mar 8, 2003 | 04:59 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Dyno of 2.0 GSR @ 10psi (ekb18c)
Its with a cat, so it looks about right. Take the cat off!
Old Mar 8, 2003 | 05:00 PM
accordfreak's Avatar
how much did it cost to tune the hondata?
Old Mar 8, 2003 | 05:02 PM
Nine's Avatar
Default Re: Dyno of 2.0 GSR @ 10psi (Arturbo)
What is ur CR?
Old Mar 8, 2003 | 05:24 PM
Tofurky's Avatar
it means everything other than the block is stock.
RS Sleeves, JE 9:1 pistons 84.5, Eagle Rods, ARP Rod Bolts, and ARP head studs.
It's ok I know you're not bashing. But about the power levels...
it has a cat. you have no idea how much power they can steal.
This wasn't tuned for 'stupid' horsepower. This was tuned for drivability to 91 octane.
I assure you, with the a tiny tiny bit more boost, no cat, new IM... it will make well into the 300's.
And until I can afford a beater or "extra car"... the boost will remain stupidly low.
[Modified by Ruckus138, 6:30 PM 3/8/2003]
Old Mar 8, 2003 | 05:27 PM
Tofurky's Avatar
hehe, i know i know! heh, i just have to wait to get an absurdly large/long glasspack, so I can run a straight pipe.
I live in **** Cop california.
Old Mar 8, 2003 | 05:28 PM
DLB1994's Avatar
why didnt the msd map sensor work
Old Mar 8, 2003 | 05:32 PM
Tofurky's Avatar
Default Re: Dyno of 2.0 GSR @ 10psi (DLB1994)
not a clue. it was getting voltage, after about an hour... the only thing we figured out, was that it didn't work.
Old Mar 8, 2003 | 05:38 PM
DLB1994's Avatar
was it a bad sensor or the msd one just dont work with hondata
am going to dyno tune my car in a few weeks with my hondata and i have the 3bar msd sensor but i dont know if it works yet my base map is for the stock one
Old Mar 8, 2003 | 06:04 PM
ekb18c's Avatar
Be carefull, not all GM or MSD 3 bar maps work with hondata.
Old Mar 8, 2003 | 06:08 PM
DLB1994's Avatar
so how do i know is it going to work before i hit the dyno
Old Mar 9, 2003 | 02:56 AM
Default Re: Dyno of 2.0 GSR @ 10psi (accordfreak)
Old Mar 9, 2003 | 03:02 AM
Arturbo's Avatar
Better than steak
25 Year Member
How do you know which ones work then?
Old Mar 9, 2003 | 03:20 AM
MiraiZ's Avatar
Old Mar 9, 2003 | 03:53 AM
T3's Avatar
T3
Default Re: Dyno of 2.0 GSR @ 10psi (MiraiZ)
Old Mar 9, 2003 | 07:37 AM
Speedworks801's Avatar
There's gotta be more power there.
Old Mar 9, 2003 | 07:38 AM
Default Re: Dyno of 2.0 GSR @ 10psi (T3)
There's gotta be more power there!
Old Mar 9, 2003 | 07:47 AM
The_Head's Avatar
Default Re: Dyno of 2.0 GSR @ 10psi (Speedworks801)
I'm kinda disappointed in IB for using MPH on the horizontal axis of the graph. they should know better.
Old Mar 9, 2003 | 08:21 AM
ekb18c's Avatar
I once thought every GM 3 bar map would work on hondata till I tried a 3 bar map from a dfi kit on hondata system. It didn't work at all. Then I got one from a speedpro kit and that didnt work either. After trying a few 3 bar maps, I just gave up and ask hondata to ship one to me.
I will have to double check with my notes at the shop but I think you need to find 749 or 748 on the back of the map sensor.
The only way to find out is to try it.
edit- why do you think there is a problem with having mph on the x-axis?
[Modified by ekb18c, 9:23 AM 3/9/2003]
Old Mar 9, 2003 | 09:24 AM
The_Head's Avatar
I just think it would be more useful to have Engine RPM's there.
