Weird ECU chip problem
Old Mar 8, 2003 | 02:18 PM
ChiBoy's Avatar
Default Weird ECU chip problem
I got adventurous and bought one of the eBay Skunk2 chips. I soldered everything in and the car runs fine with no CEL’s, but the Cruise Control light is on. The problem is that the car doesn't have Cruise Control, so I can't turn it off!.
Did I do something wrong with the install??
I know I could pull the light from the dash, but I’d rather fix it right.
Any help is appreciated.
Thanks,
G
[Modified by ChiBoy, 6:14 PM 3/8/2003]
Old Mar 8, 2003 | 07:36 PM
ChiBoy's Avatar
Default Re: Weird ECU chip problem (ChiBoy)
After a little more research, I think the ECU thinks it is lighting the "Shift up Indicator Light". Since I replaced the cluster with an EX unit, the cruise control bulb is in the same place as the SUIL on the CX cluster. Still a problem, but now I'm thinking it might be the chip afer all.
Old Mar 9, 2003 | 03:57 AM
ChiBoy's Avatar
Bump
Old Mar 9, 2003 | 06:27 AM
altoid's Avatar
eh? what? the only help i can offer is for you to find out the exact specs on your chip and if its got anything about cruise control.
Old Mar 9, 2003 | 06:59 AM
eg6ajk's Avatar
if the chip is causing the problem. then to fix it right is to get another chip. or talk to the seller, he might be able to help you out.
Old Mar 9, 2003 | 10:08 AM
ChiBoy's Avatar
Default Re: Weird ECU chip problem (eg6ajk)
Yes, I think it's the chip now. The seller wasn't much help though. He suggested pulling the bulb from the cluster.
Just to keep testing, I had a 3rd p28 that was automatic and I did the thing with RP17 & 18 to convert to 5-speed. The dash light stayed off.
Then I pulled the jumper off of one of the chipped ECU's and the light stayed off too.
The only thing I can conclude is that the program on the chip is turning on the light. I think it has something to do with the manual/automatic conversion. Pin D18 on the ECU is used for the "shift indicator" light on some MT models and is also used for the [tranmission] interlock control unit on AT models.
Since there are no CEL's it seems like part of the program is OK, but the other part didn't get the message that the car wasn't an automatic. The seller says he's never had a problem with the program, so now I don't know what to do.
Old Mar 9, 2003 | 02:56 PM
Joseph Davis's Avatar
I'm worried for you. Detonation, running low on oil, and cruise control lights are the three things most likely to blow up Honda engines. You should sue the seller for another engine, since the damage has already been done.
It's some bit of code in the base program causing your cruise light. Does the chip otherwise function the way you wanted it to? If yes, pull the associated ECU wire and forget about it.
doughboixx
Nov 30, 2008 06:06 AM
Mr.Blondie
Jul 30, 2007 01:20 PM
SkoundrelUSA
Aug 2, 2006 12:06 PM
usdmEHboy
Feb 1, 2006 08:30 AM
unstopabledj
Sep 19, 2004 08:04 PM
