ZC Guru`s I need you advice
Old Mar 8, 2003 | 10:20 AM
Alexnaderkeith's Avatar
Default ZC Guru`s I need you advice
Hello,
I`ve just installed a A/F gauge in my rex. I`m running a ZC, with port and polished TB, msd ignition, headers, intake, B&M FPR, still running PM6, but have PG7 ecu...(didn`t make difference)
My fuel pressure gauge is reading at 40. while I beleive stock should be at 35.
My A/F gauge is reading rich at idle, and will then bounce from stoich/lean/rich while driving under normal conditions. While at WOT it`s at rich aswell.
Is it normal for the engine to idle at rich or might something be off?
(I`m hooking up my ZEX kit in a couple months, and don`t want things to go BOOM!)
PLease lemme know,
Ryan
Old Mar 8, 2003 | 12:39 PM
sslude's Avatar
Default Re: ZC Guru`s I need you advice (Alexnaderkeith)
im pretty sure its suppose to run a litle rich at idle. but wtih the the sex kit, the thing you DONT want its to run lean, no? well good luck
DumpdEJ6
Oct 19, 2012 04:13 AM
cticknor666
Oct 24, 2006 06:43 PM
jdm_ef9
Apr 29, 2002 02:38 PM
97hb
Mar 21, 2002 09:13 PM
FusionITR
Mar 1, 2002 02:43 PM
