b20 w/ B16 crank
well the displacement would be 1600 cc or a 1.6 L. If you were to do this, for what ever reason you are, CTR rods would be the perfect length. If you put the B20 rods on you would have to deck plate the block or else the pistons would smash into the head.
thats the dumbest thing ive seen here in awhile
because he will have a little over 1.7l of displacment (yes 1.7 the bore is larger than the b16's) with a near perfect rod/stroke ratio?
yea thats retarded.
[Modified by Kamin, 5:14 PM 3/8/2003]
Some of us happen to have some parts (like B20 shortblocks) laying around our garages and want to find the best possible way to use them. Answering with "just use a B16" doesn't help someone who might already have a B20 and maybe even a B16 crank laying around from previous projects.
I hate seeing anyone call ANY question in this forum stupid. Makes it feel like clubsi or something.
tell you what... you want a fun block to build, sleeve and bore a CTR block to 84.5 and boost it on 10:1 CR... with a PnP head, GSR intake cam and ITR exhaust in the B16 head... lovely... can you say 400whp at 1bar?
one could only dream
2. CTR rods would not be the perfect length because the B20B block infact has a different deck height than a B16
3.That being said the rods on a B20 a little shorter because the stroke is longer, so therefore putting shorter rods on an even shorter crank would not cause to much of a collision problem....won't have to worry about 12:1 compression ratios either.
well, chances are the rod deflection on the crank may not work with the block...
thats one of those things that you would have to get all the parts together to
see how it would work and keep trying until you get it right. I wouldnt doubt that
this guy's idea was to build a de-stroked motor he could boost the crap out of and rev all day long. Having a largely oversquare setup, it would be good for tq theoretically speaking, 84/77.4 is pretty oversquare...
how about a B17? the only 99% square B series engine I know of...
Sleeve/bore and hone to 84 with a 81.4 stroke... that couldnt be too bad even for NA... but finding the block would be a real test
92-93 GSRs are rare as heck. That would be cool
little2fast4u
Aug 2, 2008 06:46 PM
