FI Car is starting and dying....CEL Someone help!
Old Mar 8, 2003 | 09:40 AM
TurbothisLS's Avatar
Default FI Car is starting and dying....CEL Someone help!
Hey,
I just drove from austin to dallas yesterday.
When I got in my car this morning to go to work, I started it and it started, but then it just died.
I tried it again and the car starts, but it just dies.
When you rev it, it will stay on after a while. The car idles really rough, with the revs moving up and down. The motor shakes alot more than it used it.
When driving, in between shifts, the car feels like it's going to die. I can hear the turbo spooling and I still get boost. The fuel pressure is normal as well.
I am getting the CEL checked out, but what do you guys think? The only thing I just changed was from my 3" exhaust back to my stock type r one.
Old Mar 8, 2003 | 10:06 AM
zojirushi's Avatar
Default Re: FI Car is starting and dying....CEL Someone help! (TurbothisLS)
maybe the o2 sensor wire is not connected properly or not connected at all.
[Modified by zojirushi, 2:06 PM 3/8/2003]
Old Mar 8, 2003 | 10:48 AM
M-EJ1's Avatar
Default Re: FI Car is starting and dying....CEL Someone help! (zojirushi)
I would definately check the O2 sensor if you just changed the exhaust. My car is doing this right now sort of, it runs kinda rough and backfires every once in a while, and I bet the CEL you're getting is CEL 43, right?
Old Mar 8, 2003 | 02:19 PM
Default Re: FI Car is starting and dying....CEL Someone help! (M-EJ1)
The CEL is for low MAP sensor voltage.
the Acura technician said that there is no voltage going to the MAP sensor.
I am running teh AFC hack by the way.
Old Mar 8, 2003 | 06:13 PM
anyone have any ideas?
Old Mar 8, 2003 | 06:16 PM
Arturbo's Avatar
Better than steak
25 Year Member
You are running the AFC-hack, right?
Old Mar 8, 2003 | 06:18 PM
UberTeg's Avatar
it sounds like limp mode, is your rev limiter at 3200?
Old Mar 8, 2003 | 07:53 PM
Mr. Softee's Avatar
Default Re: FI Car is starting and dying....CEL Someone help! (UberTeg)
make sure vafc is properly wired..sometimes those connections can get screwy.
Old Mar 8, 2003 | 09:22 PM
1bar's Avatar
Default Re: FI Car is starting and dying....CEL Someone help! (94goldjungsr)
is it possible that ur afc wiring..the map output wire coming from the afc would somehow got loose, therefore the ecu wouldnt see any voltage coming from the map correct. just a thought goodluck though
Old Mar 8, 2003 | 09:29 PM
Default Re: FI Car is starting and dying....CEL Someone help! (1bar)
Hey ART, i'm back in dallas, help!
I called Stan, and he told me to get the code, but I tried calling again later and he wasn't there.
The possibility of the AFC wiring coming off is something I've been considering. I will check that and get back to you guys.
Old Mar 8, 2003 | 11:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
I'll IM you my phone # where you can call me.
art
Old Mar 9, 2003 | 07:05 AM
Flamenco-T's Avatar
first, check for all open wires in the wiring. check the AFC harness wiring to the ECU, and your map sensor to the wiring loom.
if that doesn't solve it.
try to write down all the settings on the AFC, then reset it..to see if it's an electrical issues...
have you tried swapping MAP sesnor, just to see if your's is still good ?
call me today, I am gonna be around dallas
stan
Old Mar 9, 2003 | 07:58 AM
Default Re: FI Car is starting and dying....CEL Someone help! (Flamenco-T)
ok, i'll call both of you guys today
anyone know where dustin is?
Old Mar 9, 2003 | 12:34 PM
4U2NV's Avatar
I'm right hea... Hit me up on my celly, I left your number at my house... ...
Old Mar 9, 2003 | 08:28 PM
Default Re: FI Car is starting and dying....CEL Someone help! (99 B18B)
hey guys,
i fixed it!
the MAP sensor reference voltage wire had melted!
I just cut the section off and respliced it.
everything back to normal
dustin, i'll give ya a call tommorow
maybe you can come up to work or something
we need to all meet up one day
maybe all go down to ennis on friday?
Mohsin
Jan 3, 2008 10:28 AM
AndyD
Jul 21, 2005 07:48 PM
rasinhell
Apr 24, 2005 07:19 PM
phiberoptik
Aug 25, 2003 06:57 AM
A11MotorR
Jul 4, 2002 04:22 PM
