Turbo on ZC
hi,
I recently bought a 16G turbo and want to put it on my ZC motor.
Im trying to find various parts and would like any info that oyu all could give me.
I need to find an FMU, and a plate adapter in order to fit the turbo to a HF manifold.
Also, is there anything i should look out for?
righ tnow im only planning a maybe 4-5 psi, im not sure how high i could go with a stock block, fmu, boost controller and fpr
i plan on rebuilding hte motor, have some pistons dropped in ( possibly 89 teg flat top pistons) to lower compression, and a safc, bigger injectors, etc.
thanks,
Scott
thanks,
Scott
about 13 pounds the rods will bend and the ringlands will break.
liam
The 88-89 Integra pistons are not flat. They are domed and will yield 9.5:1 in a ZC using the stock headgasket. The 86-87 Integra pistons are flat and will yield 9.3:1 in a ZC with the stock headgasket.
Sonny
If your planning on rebuilding, get Endyn's roller wave pistons. There a little pricey but sweet as hell. as for the adapter plate, just take your turbo and manifold to a machine shop, they'll make u one for like $40
cool, thanks for the informations so far.
i have a couple more questions.
I have a blwon hf motor, so i have a manifold to use. is ther anything extra i need to do besides having an adapter plate for the turbo? and will the manifold need to be ported or anything before it bolts to a ZC? Also, will an HF oil pan fit on a zc? if so, where do i need to run the oil return line? i have a friend who can tap one for me, i just need to know where.
thanks again,
Scott
thanks again,
Scott
ridestrt
Oct 6, 2003 12:31 PM
