CEL on 90 CRX si
Old Mar 7, 2003 | 03:24 PM
CRX Si's Avatar
Default CEL on 90 CRX si
it has come on twice now... only after running for a while... goes into limp mode but when I turn it off and then back on it is fine... temp is good... oil is fairly new... new plugs, cap and rotor... fresh coolant... any suggestions???
Old Mar 7, 2003 | 04:36 PM
bryant's Avatar
Default Re: CEL on 90 CRX si (CRX Si)
Why dont you check the code when it comes on. That way you know what it is and possible could fix it.
Old Mar 7, 2003 | 04:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: CEL on 90 CRX si (Bryant)
this happens to me as well. the ECU sends code 1. I had a A/F ratio gauge so took it off and sold it. then reset the ECU and now it hardly ever sends the cel, but it still throws code 1.
Blaze
Old Mar 7, 2003 | 06:22 PM
CRX Si's Avatar
Default Re: CEL on 90 CRX si (Blaze45)
can anyone post a list of codes so when i get off my lazy as i know what i am looking at?
Old Mar 7, 2003 | 06:24 PM
bryant's Avatar
long blink = 10
short blink = 1
http://www.crxsi.com/resources/manual/ecu_codes.htm
Old Mar 7, 2003 | 06:25 PM
CRX Si's Avatar
i know that much... thanks agian...
Old Mar 7, 2003 | 11:07 PM
Shawn C's Avatar
In The Garage
I'm battling the same problem in my 90 crx si. damn code 1, its the "oxygen content" code, right? mine started doing it the other day when i misshifted and hit ~11,000-12,000 rpms. i can't believe the damn thing held together, but it did. it runs fine, but now im getting code 1.
i also now have an irratic idle. revs between 1000=1500 rpm. cel comes on after ~2 mins of driving. irratic idle stops if i unplug the TPS. i had the same exact problem on my 92 accord, and it turned out to be the IM gasket.
i just put my car back together, checked everything but the IM gasket. i guess thats tomorrow. i eliminated the EVAP control system, still doin it. damn car.
Old Mar 12, 2003 | 11:54 PM
CRX Si's Avatar
Default Re: CEL on 90 CRX si (22lbGS-R)
ok, im trowing a code 4... thats crak angle sensor right... but it only does it after the car runs for a while and then if i turn it off and restart the light goes out... i searched and read something about a dizzy bearing going bad and heating up the sensors and screwing with them... does this sound logical to you guys?
Old Mar 13, 2003 | 06:16 AM
zCivic's Avatar
bearing going bad may cause the shaft to wobble just enought to throw the sensor off and/or possably hit the sensor. BAD.... I would suggest grabing some elses and test run it on both see if throws same code in there car and vice versa
unix4linux
Nov 2, 2006 06:01 AM
VRD^don
Mar 1, 2004 04:04 PM
ZCHF
Jun 15, 2003 09:47 AM
Nu2DaGame
Nov 5, 2001 09:57 AM
