Searched with poor results- Code 6 & 14 OBD I GS-R: surging idle...
Old Mar 7, 2003 | 01:51 PM
sandman's Avatar
Default Searched with poor results- Code 6 & 14 OBD I GS-R: surging idle...
I'm having a surging idle, and it's killing my MPG! So far I've swapped the IAVC, ECT sensors to no avail, and I can't seem to figure out what is going on here(I also re-bled the coolant system). I have codes 6 and 14 and an idle that surges from 1k to 3k and at times holds at ~2k. This is constant. It happened ovenight and I need your expertise...
TIA....
[Modified by sandman, 2:52 PM 3/7/2003]
Old Mar 7, 2003 | 01:56 PM
Kamin's Avatar
Default Re: Searched with poor results- Code 6 & 14 OBD I GS-R: surging idle... (sandman)
sounds like a TPS sensor to me.
those 2 codes might be more problems but try this
when the idle is surging up and down
disconnect the TPS sensor
if it stops surging but idles at like 1500-2000 thats a problem.
if im totally wrong, wich is possible, you should pull the IACV, clean it, inspect it, and reinstall, then remove the eCT sensor and test it with a multimeter for resistance, if there is 0 ohms, it means its broken and you need a new one.
[Modified by Kamin, 2:57 PM 3/7/2003]
Old Mar 7, 2003 | 02:03 PM
D-Man's Avatar
Did you check for vacuum leaks and make sure the ground wires are ok.
Old Mar 7, 2003 | 02:06 PM
sandman's Avatar
Default Re: Searched with poor results- Code 6 & 14 OBD I GS-R: surging idle... (Kamin)
The TPS is directly on top of the IM right? Well I swapped that too. (the parts I'm throwing at it are from a good idleing motor, so I know there should'nt be a problem with the parts).
I have no vacuum leaks at all, and all grounds are tied down...
Old Mar 7, 2003 | 02:29 PM
D-Man's Avatar
You have a ECU you could swap in?
Old Mar 7, 2003 | 02:41 PM
sandman's Avatar
Default Re: Searched with poor results- Code 6 & 14 OBD I GS-R: surging idle... (D-Man)
Yes, in fact I do have a spare P72, I will try that tonight....thanks...
Old Mar 10, 2003 | 12:48 AM
sandman's Avatar
Alright, I figured it out...After a crazy idea, I decided to take the Fast idle control unit off, only to find it rattling around...I opened it up and saw the plastic screw was just chillin, so I re-tightened it and away I went, puuuurfect idle.
Damn the little things!!!!
hellrose1228
Feb 9, 2009 02:30 PM
poppypizza
May 1, 2008 07:47 PM
em1gangsta
Jan 26, 2008 03:40 PM
mafay2
Jul 4, 2005 06:35 PM
4potnick
Jul 21, 2002 10:49 PM
