will it work?
Old Mar 7, 2003 | 12:01 PM
green98civic's Avatar
Default will it work?
have a question. i think i am goin to get a b18b engine, is that a good choice? will a cable clutch that comes with the engine work in a 88 crx si>? i dont have the time to search and search for stuff related to this topic. i just want to know by asking u guys and not someone else. thanks
Old Mar 7, 2003 | 12:32 PM
Camshaft's Avatar
Default Re: will it work? (green98civic)
B18B isn't a bad install into a 88-91 CRX
You need
mount kit for B series engine
axles, modified shift linkage
possible throttle cable, possible clutch cable
Ecu is nice
Old Mar 7, 2003 | 12:37 PM
Hondasaurs's Avatar
I swaped a B16A in to a CRX and the stock clutch cable worked fine. Its a B series so it should work fine.
Old Mar 7, 2003 | 01:40 PM
Malgerus's Avatar
Default Re: will it work? (ZC_CRX)
Yup. Mine is a little too long, so I need to cut it down somehow, but it should attach no problem.
Old Mar 13, 2003 | 02:27 PM
Default Re: will it work? (Mr. S)
hey guys i need some help....
look at this site http://cgi.ebay.com/ebaymotors/ws/eB...tem=2406193782 and tell will this work in a 88 crx si. and what of engine is it b18b or b16b? can i use that tranny?? thanks
Old Mar 13, 2003 | 03:16 PM
EVOCELICA's Avatar
New User
it's a b18a, and yes you can use the trans, it will work in a CRX but you will need a modified shiftlinkage, and mount kit, your clutch cable should work and you'll need to get a 91 integra throttle cable. you can also use your si ECU but would recommend getting a pr4
Chris2001991
Dec 20, 2012 07:02 PM
VTECVillain
May 13, 2002 07:54 AM
VTECVillain
May 13, 2002 07:47 AM
