sohc vtec swap questions.
If I use the pm6 or pg7 ecu with the swap, which intake manifold can I use?
Also if I get the odb-0 to obd-1 harness is there still anymore wiring? and which intake manifold can I run?
with a OBD1 converison harness u still need to repin the distribuitor, the injectors and vtec, oil press, H2O temp
