Suspension trouble!?!?!?!
Ok...I am having a bit trouble with my suspension like it says, and I currently have stock struts and some general no name springs(I know what ur thinking) and they are a little old but until i get new ones they are fine for now...my problem is, recently I got some newer springs from, a buddy that go to an eclipse. I figured that the springs would not work but i tried them along with the sleeves anyway....they were too short..so i thought. well after putting my old coilovers back on and just using the longer sleeves from the set from a friend, I lowered it where i wanted it and it still felt like it was bottoming out.I eventually got home and had a friend push on the fender and saw that the upper control arm(U shaped thing) was hitting the inside of the fenderat the top!?!?!?! I have no idea how this is happening and I am gonna put the old sleeves back on tomorrow unless someone know anything about this.. Please help me cuz this ride really sucks!
Thanks,
Tony I also have some parts from a crx for sale if anyone needs anything...402-208-4061
Thanks,
i guess i can help
i got coiovers....
yesterday i took it for aligment
well when i install the ingalls camber kit, i noticed trhat the upper A arm was hitting my fender as well if i corrected my camber...
well when i took it for aligment they had to actually cut the inner fender where they meet in order to have some clearance for the a arms so they can go back up....
that happens if u have correct camber. if u go to -2or -3 deg of camber it will not hit. but it will eat ur tires up!
i got coiovers....
But the thing is..i don't have a camber kit..and my car isn't dropped that much..i still have enough room to fir two fingers between my tire and my fender...how high is urs from the fender to the tire?
Tony
Tony
GoodEyeSniper
Jan 8, 2008 11:16 AM
DAguyLS
22
Jul 9, 2004 04:36 PM
