I think I found out the problem for my idle rattling
Old Mar 6, 2003 | 05:59 PM
HeeroZ's Avatar
Default I think I found out the problem for my idle rattling
It seems that when the engine is at normal temperature, it would only rattle a little. But at the exact time I do something like lower my window or turn on the air conditioner, my engine starts to rattle and idle at less than 200. My whole car would stall. I came to a conclusion that the windows and air conditioner might be draining too much power or something. Is there a way for me to determine this and fix it, or maybe do some tests? You guys think I might need a new battery? ( Which I doubt ). Thanks.
Old Mar 6, 2003 | 06:07 PM
JDM GIRL's Avatar
Default Re: I think I found out the problem for my idle rattling (HeeroZ)
I posted on this a while ago. This happens to me a lot and it has gotten a lot worse, but I believe it is the AC vent. I am going to get mine checked out soon. I will let you know what the exact problem is as soon as I find out.
New battery? I don't think so. But then, I am on H-T to learn, because I am not too knowledgeable in this area. It's just what I have heard.
[Modified by JDM GIRL, 10:09 PM 3/6/2003]
Old Mar 6, 2003 | 06:43 PM
HeeroZ's Avatar
Default Re: I think I found out the problem for my idle rattling (JDM GIRL)
Oh really? Once you get it checked out, please tell me ASAP. Does your car idle also when you roll down or up your windows? And yea, I'm always learning something new on these boards, hehe.
Old Mar 6, 2003 | 07:15 PM
Quiklude's Avatar
if you power windows are causing that much of a draw to make you idle at a way low rpm might wanna have your charging system looked at as well as the battery
Old Mar 7, 2003 | 11:14 PM
HeeroZ's Avatar
Default Re: I think I found out the problem for my idle rattling (Quiklude)
yeah, but for some reason my car would idle like that at hot temperatures without touching the windows nor air conditioner... so it must be 2 things combined causing this problem.
fessup
Honda CR-V & Element
Dec 7, 2017 01:11 PM
1.5 ef
May 25, 2013 06:11 AM
LST2
Jun 24, 2008 11:53 AM
bob16ost
Feb 10, 2004 11:41 AM
