Turbo Sohc, What flywheel should i Use?
Old Mar 6, 2003 | 01:51 PM
shivic's Avatar
Default Turbo Sohc, What flywheel should i Use?
is a good flywheel and what lbs would you recommend.
Old Mar 6, 2003 | 01:52 PM
genop's Avatar
Default Re: Turbo Sohc, What flywheel should i Use? (shivic)
stock has always worked good in my car, and I personally know of a few people that use the stock flywheel in their race cars....
Old Mar 6, 2003 | 01:54 PM
Midwestrider's Avatar
Some will say stock, if aftermarket look at the ACT Streetlite 12.5lb's
Old Mar 6, 2003 | 01:55 PM
genop's Avatar
what kind of power are you looking to make?
Old Mar 6, 2003 | 02:06 PM
shivic's Avatar
Default Re: Turbo Sohc, What flywheel should i Use? (genop)
i want to run tuned 8lbs.
Old Mar 6, 2003 | 02:11 PM
genop's Avatar
stock. spend it on a clutch or something that you really need....
Old Mar 6, 2003 | 02:29 PM
shivic's Avatar
i bought an act clutch for the setup. what am i forgeting before i drop in the motor. im doing the water pump and belt. should i do the head gasket.
philcivicjordan
Transmission & Drivetrain
May 23, 2015 04:55 AM
tweekerz
Jul 28, 2006 07:43 PM
allmotorek8
10
Nov 3, 2005 06:37 PM
jdmjeff
Nov 11, 2003 04:18 AM
creechrr
May 16, 2003 11:42 AM
