brake pads
Old Mar 6, 2003 | 11:56 AM
ajd2004's Avatar
Default brake pads
i've been smelling this burning smell in my '89 accord, and i figured out its coming from the tire so i assume the brake pad is messed up. I'm planning on buying a set and replacing them. How much should i pay, and where should i get them from?
Old Mar 6, 2003 | 12:08 PM
urbanlegend21's Avatar
New User
Default Re: brake pads (ajd2004)
any auto parts store, should not be more than $50
Old Mar 6, 2003 | 01:01 PM
JimBlake's Avatar
If its bad enough to smell, you might be buying rotors & calipers, too. Make sure your calipers work OK, or you'll be doing it again, soon.
Old Mar 6, 2003 | 01:13 PM
h22accordvtec's Avatar
Default Re: brake pads (JimBlake)
You should check your pads for wear first. If you see one is being worn more then the other you will need to do a complete service on your brakes. eg. brake fluid bleed, grease the caliper pins resurface the rotors or change them if needed, swap out the pads. When you brake how does your car feel? does it push to the right or left when you step on the brake pedal. If so, one of your calipers could be going out.
Old Mar 6, 2003 | 05:21 PM
ajd2004's Avatar
Default Re: brake pads (h22accordvtec)
it doesn't move one way more than the other or anything, at least not that i notice. a couple months ago a guy put a rebuilt engine in it and he fixed everything up, so nothing big should be wrong with it. but i guess you never know
user 93082343
14
Mar 23, 2009 02:49 PM
yaya
May 19, 2003 08:18 PM
internet ay
Apr 28, 2002 07:32 AM
integra0260
Oct 21, 2001 08:09 AM
