heres my dyno @ 11 psi
Old Mar 6, 2003 | 07:25 AM
B00STeD's Avatar
Default heres my dyno @ 11 psi
I need a bigger turbo for this motor!!
276 whp and 225-230 wtq @ 11 psi
greddy turbo
sfp manifold
hks external wastegate
greddy type 31 i/c
type s blow off valve
darton sleeves 84 mm
je 9:1 pistons
crower rods
holley 750 cc injectors
hondata 3b
obd II->obd I
chipped p28
ok heres the graph on 11 psi
heres the a/f graph
[Modified by B00STeD, 11:26 AM 3/6/2003]
[Modified by B00STeD, 11:28 AM 3/6/2003]
[Modified by B00STeD, 11:29 AM 3/6/2003]
Old Mar 6, 2003 | 07:27 AM
alpha's Avatar
Default Re: heres my dyno @ 11 psi (B00STeD)
It's small so I can't read it too good. Does it say 275WHP? Nice numbers and a nice setup
Old Mar 6, 2003 | 07:29 AM
B00STeD's Avatar
Default Re: heres my dyno @ 11 psi (0x64)
how do i make it bigger??lol
Old Mar 6, 2003 | 07:34 AM
alpha's Avatar
I bet someone here can enlarge it in Photoshop without making it look like crap.
Old Mar 6, 2003 | 07:36 AM
swrdply400mrelay's Avatar
I dunno what you're talking about; I think those numbers are great! What kind of exhaust are you running?
Old Mar 6, 2003 | 07:44 AM
RAWB's Avatar
Good numbers man, are you runnin a GSR engine?
Old Mar 6, 2003 | 07:49 AM
DIRep972's Avatar
Smarter than you
hey man I think those are pretty good #'s. ur making really good torque it just falls off up top more then normal on a turbo gsr. a bigger turbo would definitly help solve that problem. ur a/f and torque curve look real nice.
[Modified by DIRep, 8:49 AM 3/6/2003]
Old Mar 6, 2003 | 07:58 AM
DLB1994's Avatar
Default Re: heres my dyno @ 11 psi (DIRep)
why you running only 11psi on that setup
Old Mar 6, 2003 | 08:00 AM
integranator's Avatar
Default Re: heres my dyno @ 11 psi (DLB1994)
what f-in motor are you running? Details!!
B00STeD's Avatar
Default Re: heres my dyno @ 11 psi (swrdply400mrelay)
no dont take me the wrong way I'm very happy with the #'s, but the motor is built for more and its spooling the crap out of the turbo, im building boost around 2300 rpm and full boost around 4500, thats fast, sometimes too fast for the street.
I am running a full 3 inch exhaust except for downpipe with a magnaflow muffler.
Old Mar 6, 2003 | 08:02 AM
B00STeD's Avatar
Default Re: heres my dyno @ 11 psi (RAWB)
yes its a gsr with a 84 mm bore (darton sleeves)
Old Mar 6, 2003 | 08:04 AM
B00STeD's Avatar
Default Re: heres my dyno @ 11 psi (integranator)
I dont have the graph for the 15 psi run, I made around 310 whp and around 250 wtq.
the motor info was stated above, basically built bottom end (2.0) stock head, bigger injectors and hondata.
Old Mar 6, 2003 | 08:10 AM
JDM92CX's Avatar
Great numbers for 11psi
Old Mar 6, 2003 | 08:17 AM
B00STeD's Avatar
Default Re: heres my dyno @ 11 psi (xJDM88EF9x)
thanks alot man.
Old Mar 6, 2003 | 08:30 AM
Are you going to upgrade the turbo (port turbine housing, upgrade to a 20G comp, etc.) or are you going to go with a completely different turbo like a T3/T4?
Old Mar 6, 2003 | 08:31 AM
Project_SOHC_EX's Avatar
Those numbers aren't that good. I believe Direp9172 was making 277 and 243@ 12psi on a completely STOCK LS, just running the revhard or maxrev kit. But I guess it's nice if you say so.
Old Mar 6, 2003 | 08:38 AM
Sleepin''s Avatar
Default Re: heres my dyno @ 11 psi (Project_SOHC_EX)
maybe this will help....slightly bigger:
Old Mar 6, 2003 | 08:56 AM
BoostedSi's Avatar
Default Re: heres my dyno @ 11 psi (Sleepin')
thats not too bad
Old Mar 6, 2003 | 09:32 AM
rondigs's Avatar
Default Re: heres my dyno @ 11 psi (BoostedSi)
Seems pretty good to me.
But yeah, I feel ya. If the motor is built and can take considerably more....give it to it. Torque looks good in relation to the HP.
Old Mar 6, 2003 | 09:37 AM
avividmemory's Avatar
Default Re: heres my dyno @ 11 psi (rondigs)
very nice numbers
Old Mar 6, 2003 | 09:41 AM
B00STeD's Avatar
you said it yourself, he did it on a maxrev kit,alot bigger turbo than my greddy kit. trust me that makes a difference.If I put a bigger turbo on this bad boy trust me I would make more than he did with say a precision sc60.
also I will be upgrading within a year or so to a bigger turbo but for now this is perfect for what I use it for, mainly street driving and not too much tracking
[Modified by B00STeD, 1:42 PM 3/6/2003]
Old Mar 6, 2003 | 09:46 AM
Midwestrider's Avatar
DIRep has a Revhard kit on his LS..
BTW.. nice #'s congrats..
Old Mar 6, 2003 | 09:49 AM
I Like Boost's Avatar
Who tuned the hondata for you? I have pretty much the same setup but with a bigger turbo (SC 52) and i made 325whp@14 psi. Frank at SFP tuned it earlier this week.
Old Mar 6, 2003 | 09:59 AM
FredoSP's Avatar
I think its good
Look into the 20G and you'll make more power ...
Old Mar 6, 2003 | 10:05 AM
Default Re: heres my dyno @ 11 psi (FredoSP)
FredoSP: Are you looking into going with an external wastegate still?
