heres my dyno @ 11 psi
I need a bigger turbo for this motor!!
276 whp and 225-230 wtq @ 11 psi
greddy turbo
sfp manifold
hks external wastegate
greddy type 31 i/c
type s blow off valve
darton sleeves 84 mm
je 9:1 pistons
crower rods
holley 750 cc injectors
hondata 3b
obd II->obd I
chipped p28
ok heres the graph on 11 psi
heres the a/f graph
[Modified by B00STeD, 11:26 AM 3/6/2003]
[Modified by B00STeD, 11:28 AM 3/6/2003]
[Modified by B00STeD, 11:29 AM 3/6/2003]
greddy turbo
sfp manifold
greddy type 31 i/c
je 9:1 pistons
crower rods
hondata 3b
obd II->obd I
chipped p28
heres the a/f graph
Re: heres my dyno @ 11 psi (0x64)
It's small so I can't read it too good. Does it say 275WHP? Nice numbers and a nice setup
Re: heres my dyno @ 11 psi (B00STeD)
Smarter than you
hey man I think those are pretty good #'s. ur making really good torque it just falls off up top more then normal on a turbo gsr. a bigger turbo would definitly help solve that problem. ur a/f and torque curve look real nice.
[Modified by DIRep, 8:49 AM 3/6/2003]
Re: heres my dyno @ 11 psi (swrdply400mrelay)
I dunno what you're talking about; I think those numbers are great! What kind of exhaust are you running?
I am running a full 3 inch exhaust except for downpipe with a magnaflow muffler.
Re: heres my dyno @ 11 psi (integranator)
why you running only 11psi on that setup
what f-in motor are you running? Details!!
Are you going to upgrade the turbo (port turbine housing, upgrade to a 20G comp, etc.) or are you going to go with a completely different turbo like a T3/T4?
Those numbers aren't that good. I believe Direp9172 was making 277 and 243@ 12psi on a completely STOCK LS, just running the revhard or maxrev kit. But I guess it's nice if you say so.
Re: heres my dyno @ 11 psi (BoostedSi)
Seems pretty good to me.
But yeah, I feel ya. If the motor is built and can take considerably more....give it to it. Torque looks good in relation to the HP.
Re: heres my dyno @ 11 psi (Project_SOHC_EX)
also I will be upgrading within a year or so to a bigger turbo but for now this is perfect for what I use it for, mainly street driving and not too much tracking
[Modified by B00STeD, 1:42 PM 3/6/2003]
Who tuned the hondata for you? I have pretty much the same setup but with a bigger turbo (SC 52) and i made 325whp@14 psi. Frank at SFP tuned it earlier this week.
