JDM 10.6:1 H22A pistons
not to sure about this but you can try http://www.optauto.com or you can always check in the classifieds..worth a shot
I'm putting an Endyn built supercharger on my prelude. SO I want everything to stock figures ie. pistons, valves, rods. I just want stronger equipment because I plan on going higher than 8 PSI. ANyone know any places. I don't have the cash and a shop to resleeve.
[Modified by Riptide101, 6:12 PM 3/6/2003]
[QUOTE]I'm putting an Endyn built supercharger on my prelude. [QUOTE]
How much is that costing you? I would really like to know, also are you buying the SC or a kit from him?
I have already bought a JRSC for a 97-2001. The thing is I have a 94 VTEC. I will soon be having CAZ in Arizona to put it on. While Endyn is doing the work I want to put all my other parts in ie Springs, retainers, rods. The rebuild is about 1600. Thats rebuilding everything and ceramic coating the inside to bring temps down. After it can put down according to them 13-15 PSI. I won't be going that high but I like it because the power is available all the time. I don't have to worry about lag.
http://www.theoldone.com/sc/jackson-upgrade.html
[Modified by Riptide101, 8:17 PM 3/6/2003]
wouldn't it better to have the usdm pistons for the lower compression, just to be n the safe side.
i'm sure jdmhondaparts.com or passwordjdm.com will have the stock jdm pistons. also check with other motor importers like hmotorsonline.com since they deal in volume, i bet they get some cracked block h22s, but salvage what they can.
You cant run 11:1 CR with a supercharger at 8+ psi....it will be dead in a week....way too high pressure for cast pistons and our weak rings.....if your spending all this money go forged, its your only hope to hold 13 psi or whatever.....
PrettyLude
Feb 8, 2004 07:04 PM
dvp95
May 15, 2002 11:38 PM
