h23a questions
Old Mar 5, 2003 | 10:09 PM
mikeyvt's Avatar
Default h23a questions
Ive been looking for a h22a to buy when all of a sudden a h23a dropped out of the sky, actually someone i know owns a mechanic shop and said he would give me the h23a for free, only problem is that it has a bad connecting rod. I have a few questions.
1. Has anyone boosted this motor? How good is this motor at handling boost?
2. Will this motor bolt up to my F22B2 Tranny (I have a 94 accord LX)
3. Is this motor good at all?
I do plan to take the motor, just wanted to see if anybody knew if this motor was good at handling boost. Im looking at rebuilding the whole thing. thanks for any help
Old Mar 6, 2003 | 01:30 AM
Regulator's Avatar
Default Re: h23a questions (mikeyvt)
H23's are excellent motors to boost. i think that if you upgrade the pistons to aftermarket, you have to resleeve the motor (or so i heard). it will bolt right up to your tranny. it is an excellent alternative to an H22, it's cheaper, and it holds boost well.
Old Mar 6, 2003 | 03:06 AM
One2chi's Avatar
Default Re: h23a questions (95vtecaccord)
yea, my friend has an h23 in his prelude (it came stock) and its pretty quick, id definately take one fro free.
Old Mar 6, 2003 | 05:00 AM
paul9luap's Avatar
Default Re: h23a questions (One2chi)
if you want to run aftermarket forged pistons, yes, you have to resleeve because of the FRM lining. good motor choice. there are some guys making some very impressive numbers on here with that motor. DLB1994 just had a topic about his, also Boostedh23a1 in the prelude forum is doing some good work. I'm not sure who else.
EDIT: I would also recommend replacing the main bearings and piston rings. A lot of the h23's off of ebay or other sites seem to have problems with those.
[Modified by paul9luap, 9:06 AM 3/6/2003]
Old Mar 6, 2003 | 08:25 AM
h22accordvtec's Avatar
Default Re: h23a questions (paul9luap)
You can IM exospeedamcrx here in Honda-tech. He can get good prices on motor packages that includes resleeving, rod and piston, and anything else you want to do to your newly accuired H23.
Old Mar 6, 2003 | 10:31 AM
Nick H's Avatar
New User
Default Re: h23a questions (h22accordvtec)
to answer your original question, that motor is an excellent choice for boosting...if you would like to get crazy with it, resleeve the block and replace the rods, pistons, and bearings...but, the block is already pretty damn strong as it is closed deck from the factory as opposed to the open deck design of the h22...this will add strength to the sleeves so that you are able to push more boost on stock internals...the rings are somewhat questionable if you do decide to go with stock internals, but if you go aftermarket, new ones should come with new pistons...the stock rods would be fine if you shot peened (sp?) them unless you plan on running crazy boost...other than that, just modify the head to get the air flowing better and you should be set...but yes, the h23 is a great motor to start with...the extra 100 cc of displacement is nice in a 4 cylinder...
Old Mar 6, 2003 | 08:38 PM
mikeyvt's Avatar
Default Re: h23a questions (Nick H)
well i have finally decided what i am going to do, im going to rebuild it back to stock, and run nitrous for a while, i do plan to boost it but i want to get the motor in my car before summertime, any advice or suggestions? the person who suggested that i just rebuild it back to stock was a friend of mine, he has a 10 sec gsx,
Old Mar 6, 2003 | 09:38 PM
95 GaNgStA AcCoRd's Avatar
I'm starting to lean more on the H23 side too, because I want something to build and boost 15 psi daily on. But I don't like the idea of spending all that $$$ on an engine that only has 30 more hp than the one I already have in my car. Thats a tight deal man, good luck with it, let me know how it turns out.
Old Mar 6, 2003 | 10:07 PM
mikeyvt's Avatar
Default Re: h23a questions (95 GaNgStA AcCoRd)
i will, i plan to post pics of the rebuild and the install if people want
Old Mar 7, 2003 | 04:21 AM
Stew Pidasso's Avatar
Please do.
Old Mar 7, 2003 | 08:11 AM
For a daily driver I would save my money and not buy the H23 and just turbo the F22.
Old Mar 7, 2003 | 08:40 AM
Brandon's Avatar
Life is Suffering
For the money it takes to rebuild and put nitrous on the H23, you could boost your F22 and make MORE power. For around $1500 you could have a very good turbo setup.
Old Mar 7, 2003 | 12:46 PM
One2chi's Avatar
I'm starting to lean more on the H23 side too, because I want something to build and boost 15 psi daily on. But I don't like the idea of spending all that $$$ on an engine that only has 30 more hp than the one I already have in my car. Thats a tight deal man, good luck with it, let me know how it turns out.For a daily driver I would save my money and not buy the H23 and just turbo the F22.
me too.
Old Mar 7, 2003 | 03:27 PM
mikeyvt's Avatar
i could save money and build a nice turbo f22 but i like to be different. plus the motor was for free so i can tear it apart and build it while i still drive my car. my car is a daily driver so its not like i can just pull the motor and build it
I do plan to boost it, just going to run nitrous for this summer, i want to get the motor in as soon as i can, i plan to have another car by sept so i can pull that motor back out.
[Modified by mikeyvt, 12:28 AM 3/8/2003]
Old Mar 7, 2003 | 04:01 PM
KTeller8's Avatar
Default Re: h23a questions (F22Turbo)
<<--- begs to differ bout a "very good" turbo setup
Old Mar 7, 2003 | 07:24 PM
Default Re: h23a questions (KTeller8)
F22 has 125 miles on it, and my goal is to put down DLB1994 numbers (400whp); is that even possible with a f22?
Old Mar 7, 2003 | 09:12 PM
mikeyvt's Avatar
yea it can be done with a good turbo setup but like i said, i like to be different, and i only have one car so i cant afford to work on my engine out of my car
swiftsmiles
Mar 21, 2011 10:09 PM
Teddieb15
Dec 4, 2008 09:40 AM
power11
Jun 10, 2007 06:47 PM
team703
Mar 19, 2006 05:35 PM
DLB1994
Nov 8, 2001 01:04 AM
