oil leak from distributor?
Old Mar 5, 2003 | 05:39 PM
quikrpm'z's Avatar
Default oil leak from distributor?
is it possible for the distributor to leak oil? Not talking about the cap but where it bolts up to the head.
Old Mar 5, 2003 | 06:02 PM
FF-Greg's Avatar
Default Re: oil leak from distributor? (quikrpm'z)
It could be your cam plug or cam seal, Mine is also leaking at the moment i just have to get the money together to fix it. I hope that helps lates Greg
Old Mar 5, 2003 | 06:14 PM
Project SSAP1's Avatar
most likely a cam seal...also get a new valve cover gasket and u will be ok
Old Mar 5, 2003 | 06:25 PM
97gSrkId88's Avatar
Default Re: oil leak from distributor? (Project H22DC4)
there is a seal on the back of the distributer
Old Mar 5, 2003 | 06:44 PM
AlphaKennyWun's Avatar
Default Re: oil leak from distributor? (97gSrkId88)
I just changed mine. There is an o ring inside the distributor $2 from dealer. Its 2 bolts to remove the distributor. takes 5 minutes. change it!
Old Mar 5, 2003 | 08:55 PM
quikrpm'z's Avatar
Default Re: oil leak from distributor? (S03Burner)
So yours was leaking oil? THe distributor can only go on one way right.
Old Mar 5, 2003 | 09:41 PM
Mr.Integra's Avatar
cast.aluminum
Dec 15, 2014 10:53 AM
jchrm80
May 17, 2009 09:27 AM
sonson6
Mar 20, 2007 07:56 PM
cbags05
Jan 8, 2007 06:40 PM
hatchbro
Oct 13, 2004 09:00 PM
