Burning Oil ?
Old Mar 5, 2003 | 02:59 PM
BI8C1vic's Avatar
Default Burning Oil ?
I have a GSR in a hatch and I usually drive it hard, I changed my oil about a month ago and I burned enough oil that my Vtec no longer worked is this a big concern?
Old Mar 10, 2003 | 04:00 PM
boostsohfast's Avatar
Default Re: Burning Oil ? (BI8C1vic)
this is a huge concern. you probably burnt your rings which would explain that low compression your motor has. i would suggest a total re-build or a new motor. you'd probably be faster with a nice fresh d15.
Old Mar 10, 2003 | 04:07 PM
PhatOptimo's Avatar
If your motor is know to burn oil it's a <U>GOOD</U> idea to check it regularly. If not your motor will die a slow death eventaully leaving you hybridless or even worse stranded. Betta get a cell phone if you don't have one.
Old Mar 10, 2003 | 06:04 PM
b19coupe's Avatar
Do an oil consumption test to determine exactly how much oil you are actually burning. Top off the oil to the full line, and check your oil regularly, keeping track of how many miles it takes to burn a quart of oil. Sounds like you are burning a substantial amount, you may be looking at valve guide seals, rings, or even a bore job with oversize pistons and rings. Also make sure to check for any oil leaks. If you are burning the oil, you should see blue smoke when you rev the engine up. Good luck.
Old Mar 10, 2003 | 07:26 PM
Default Re: Burning Oil ? (b19coupe)
damn grizz too bad your odometer doesn't work either....looks like that test is out the window...haha...i'm just messin with ya man...we'll see who has the braggin rights after fri. night at the track
Old Mar 10, 2003 | 07:58 PM
sweet's Avatar
Default Re: Burning Oil ? (boostsohfast)
buring excessive amounts of oil like that is not a good sign.
rings may be worn terribly, valveguide seals also. maybe a major oil leak that you didn't see. always make sure you have enough oil in the motor, even if it means checking the level a couple times a week. if you drive hard and long then it's gonna disappear quickly.
Old Mar 11, 2003 | 12:02 AM
jansenrw's Avatar
mate samething happened in my R,
Am curently rebuilding the engine... GEt it checked out dude. I'm 7K in debt!!!
I need new pistons and re-grind crank.. And to add insult to injury, my ITR only has 14000 kms
Jansen
Old Mar 11, 2003 | 09:15 PM
TimoneX's Avatar
New User
You should run a compression &/or leakdown test to figure out where the oil is going.
210jdmgsr
Aug 15, 2007 03:55 PM
Sl0wEK
Dec 5, 2004 10:12 PM
silvlude
Jul 31, 2003 05:12 PM
underpressure02
Nov 1, 2002 09:50 AM
StormShadow
Oct 5, 2001 12:49 PM
