brake problem?
Old Mar 5, 2003 | 11:47 AM
SamC's Avatar
Default brake problem?
when I hit the brake, I could felt the front pass wheel shake. Does that means I need to replace the brake? or is the rotor wrapped? I know how to check if it's the brake pads but how would I know if the rotor needs to be replaced or not?
Thanks Guys.
Old Mar 5, 2003 | 11:51 AM
joe_bocc's Avatar
Default Re: brake problem? (SamC)
if the wheel is shaking under braking, then it would most likely be a warped rotor. Depending on how bad it is and what kind of shape your rotor is in, you might me able to machine the rotor true on a lathe.
Old Mar 5, 2003 | 12:04 PM
fathergoose's Avatar
Default Re: brake problem? (joe_bocc)
It's gonna cost less if you change your rotors yourself than going to shop to get them machined. You cannot do that yourself. Get new rotors.
usdmftw
Mar 26, 2012 04:02 PM
SHG_Claudio
Dec 29, 2008 07:12 AM
blue74
Mar 20, 2008 10:51 AM
JKingCivicSi
Apr 16, 2006 01:10 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
