D16z6 vs. Mini Me
If you do a mini-me, AND convert to obd-1 then the mini-me is better due to higher compression, but typically mini-me's stick to obd-0 and in that case the d16z6 will still put out a little more power due to better fuel curves, also obd-1 dizzy's are more reliable.
From: the asshole of america..., upstate new york, USA
it is said that the a6 block is stronger than the z6?!?!
you don't have to pull the motor to just swap a head.
CR goes from 9.2 to around 10:1 with mini-me.
the z6 head flows alot better than the a6.
downsides:
mounting distributor
making the vtec work
downsides:
area608EG
May 17, 2008 03:31 PM
projectef
Mar 30, 2006 10:54 PM
