Please check my Compression Test
Old Mar 5, 2003 | 11:34 AM
-iLLuZioN-B18C1's Avatar
Default Please check my Compression Test
not sure what CR i am running, supposedly i got jdm itr pistons. but not sure
do these Compression numbers resemble numbers that jdm itr pistons might put out on a GSR motor?
1st 235
2nd 240
3rd 240
4th 235
Old Mar 5, 2003 | 11:41 AM
Tinker219's Avatar
Default Re: Please check my Compression Test (jvithayapun)
they are a lot higher than stock...hondas usually run 180-190...
Old Mar 5, 2003 | 12:01 PM
Default Re: Please check my Compression Test (Tinker219)
b/c i have jdm itr pistons in my GSR block.
Old Mar 5, 2003 | 12:02 PM
b18bturbo's Avatar
those are just right for the jdm gsr pistons 240-245 range all day long
Old Mar 5, 2003 | 12:05 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
just to back up tinker mine was 185-180-180-185
[Modified by HybridcivicLS-T, 3:05 PM 3/5/2003]
Old Mar 5, 2003 | 12:58 PM
95hybridcivic's Avatar
I have a stock 95 jdm B18c and I did a compression test on it last weekend and it was at 245 all the way across.
gritsak's Avatar
Default Re: Please check my Compression Test (HybridcivicLS-T)
i went 220, 225, 225, 220 on a stock 95 gsr motor a couple weeks ago
Old Mar 5, 2003 | 01:01 PM
Tinker219's Avatar
Thanks for the B-up...I re-read how I posted it, and I sounded like a nard...so ya. I had a GSR head on my LS block and had low 180's one 178....I thought VTEC heads raised compression...
Old Mar 5, 2003 | 01:12 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
you still have the 9.2.1 stock pistons.
[Modified by HybridcivicLS-T, 4:14 PM 3/5/2003]
bean18c1
Apr 2, 2010 01:07 PM
98h22
Feb 26, 2006 06:50 PM
joshmycell
Mar 28, 2005 01:40 AM
speedymon
Dec 19, 2001 04:42 PM
Tyson Ballou
Nov 8, 2001 05:50 AM
