oil fouled spark plugs
Old Mar 5, 2003 | 11:28 AM
respectblades's Avatar
Default oil fouled spark plugs
ok i have oil deposits on my spark plugs.......
any suggestions on how to correct this... right now its pretty slight but i dont want it to get worse
Old Mar 5, 2003 | 12:43 PM
Perfectionist's Avatar
Default Re: oil fouled spark plugs (respectblades)
If you have actual oil fouling on the tips of the plugs, as opposed to on the body that comes from a leaking valve cover grommet... a short term fix would be to run plugs that are one heat range hotter than what you have now.
The ultimate fix would be to correct the oil burning problem. This could be valve stem seals, and/or oil control rings on the piston$.
Old Mar 5, 2003 | 01:24 PM
.BULLET.'s Avatar
From: kapalua,los angeles,las vegas, HI,CA,NV, United States
Default Re: oil fouled spark plugs (Perfectionist)
i learned about this in class yesterday...there are a few things u need to do in order to find out...check compression of each cylinder...make sure the spark plugs are on tightly...run the car again....if oil is still building up on the spark plugs, u could have a blown gasket..or bent valves...get that thing fixed otherwise, that motor is gone.
murrellington
Mar 21, 2016 05:11 PM
KloC 95 EG
Sep 4, 2006 09:14 PM
Mr.Speed
10
Jun 18, 2005 06:15 PM
Trumpster
Oct 30, 2004 03:24 PM
Digital-R
Aug 3, 2001 11:07 AM
