Well, I have my oil leak nailed down to a headgasket, now..which one for boost?
I just want a good one that seals nicely with stock head bolts. I was thinking OEM honda, but any other suggestions would be fine.
mike
mike
thanks a bunch bud! im frusterated with my car/life right now and it helps when people help me out
thanks a bunch!
mike
thanks a bunch!
mike
headgasket eh? im still going to send you a cnc/TIGed manifold to replace the shitty one...I knew it wasnt the turbo
sucks its a HG though
http://www.hondaautomotiveparts.com/...28DOHC+VTEC%29
is it true I should replace the head bolts too?
if so, do I need 1-#7 headgasket and 10-#19 (bolts)?
thanks,
mike
thanks,
mike
btw: how much is labor usually for this job?
if you have somebody do it...a lot. pry $4-800
thanks bud!
thanks bud!
ARP headstuds would be the best way to go as they are reusable and provide added strength over stock headbolts. Paul
thanks..btw: before I get this fixed for sure, should I try taking the valve cover off and making sure the bolts are torqued?
thanks,
mike
thanks,
mike
well, if you pay for somebody to fix it, you shouldnt have to...
Thanks again guys!,
mike
Black R
Dec 7, 2012 03:35 PM
