B18 CRX Throttle cable
Old Mar 5, 2003 | 08:21 AM
BorderM3's Avatar
Default B18 CRX Throttle cable
What do you guys use for a throttle cable when swapping a B18A1 in a CRX.
Our engine didnt come with the throttle cable on the intake manifold. And it doesnt look like it will work judging by the location the holes are drilled.
Also whats the round vacuum diaphram device that has the word up on it on the side of the manifold??? Im assuming this isnt necessary on a CRX since the D series motors do not have this
Old Mar 5, 2003 | 08:45 AM
stealth civic's Avatar
Default Re: B18 CRX Throttle cable (BorderM3)
Use a 90-93 integra throttle cable. Im not sure what diaphram you are talking about, got a picture?
Old Mar 5, 2003 | 08:55 AM
zCivic's Avatar
Default Re: B18 CRX Throttle cable (stealth civic)
If its on the mani its not used. You can plug it or leave it open. It orginally goes into the intake tube.
[Modified by zCivic, 12:56 PM 3/5/2003]
Old Mar 5, 2003 | 09:23 AM
BorderM3's Avatar
OK thanks guys i will get the throttle cable.
I dont have a pic of it unfortunately
Old Mar 5, 2003 | 10:30 AM
Malgerus's Avatar
Do you mean the dashpot? It's debatable whether you use it or not. My B16A has one and I have it hooked up.
Old Mar 5, 2003 | 11:33 AM
BorderM3's Avatar
Default Re: B18 CRX Throttle cable (Mr. S)
no idea...it looks like it has a diaphram on it to regulate air to the IAC maybe?
Old Mar 6, 2003 | 09:24 AM
BorderM3's Avatar
Just lookd on alldatapro.com
FYI the dashpot is the one hook don the throttle
The one im talking about is called the air boost valve
Old Mar 6, 2003 | 09:55 AM
zCivic's Avatar
its mounted on the intake mani though right not the T/B I've always seen it pluged unless you have all the teg hoses and intake piping.
Old Mar 6, 2003 | 10:03 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
That is the dashpot.. it controlls the high idle, for the AC.. i took mine off, and used a vacuum plug.. worked great.. or, you could go with the ITR manifold, and be gone with alot of extra crap.
Old Mar 6, 2003 | 11:43 AM
BorderM3's Avatar
Default Re: B18 CRX Throttle cable (Built B16A)
its called the air boost valve.
I looked it up on alldatapro.com
Old Mar 6, 2003 | 12:04 PM
Slurp56's Avatar
AC equipment. Not needed unless your running Air Conditioning.
Its this thing, right?
Old Mar 6, 2003 | 12:09 PM
Built B16A's Avatar
Default Re: B18 CRX Throttle cable (Slurp56)
that, and i belive the one to the left of that.. sorta hard to see in that post, but its behind the clutch cable.. if you look at it.. it controls the butterfly.. thats just a vaccum advance.
Old Mar 6, 2003 | 12:23 PM
BorderM3's Avatar
YUP!!!
Thanks
Also thanks to built b16a i didnt know that one on the throttle controlled timing adv. makes perfect sense, since its a elec. advance system! COOL!!
Old Mar 6, 2003 | 06:06 PM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
please explain to me how "throttle controlled timing adv." works?
autoxthis
11
Aug 9, 2008 11:52 AM
SpoonEk253
May 20, 2006 11:42 AM
Art701
Aug 15, 2004 05:41 PM
mustbenu
Dec 30, 2003 03:38 PM
89sir-9
Mar 17, 2002 12:04 AM
