93 Cx A/C removal & fuel / other lines. Engine Removal Pt.2! **56k grab a pillow**
I have posted this also in the Eg forum. I feel this thread can be very helpful if the right info is provided. There is nothing like working on your car and having pics with detailed instructions to guide you along. I know a lot of you probably don't visit the Eg civic forum and this is definitely tech / engine related so that is why I am posting it here as well. If we're not suppose to double post please excuse me and it won't happen again.
I know there are a few threads that talk about removing the A/C lines and all. I was outside working on pulling the Cx motor once again. In a short time I got the radiator out, splash guard, bumper off, intake box (bumper has to come off to get this), and that's about it
Now there are just a bunch of hoses left and yep pics for you guys to tell me what I am suppose to do
If you guys can tell me using the pics how exactly I cna drain the freon for the A/C that would be great. I guess I should of took it to Jiffy Lube before I removed the axles, shift linkage, and everything else. Now I guess I've got to do it the ghetto way. Is there anyway I can get around drainging the freon and just leave the A/C intact to the motor? I'm thinking not since I have to disconnect the lines to remove the engine.
I have the hoses #'ed so you guys can easily tell me which ones I need to mess with or not:
What are those 2 steel lines behind the battery tray? Looked like they are connected to the A/C. Can these be removed?
Any idea what hose this is coming out the firewall? It's just hanging there. Could be something my brother disconnected that other week when he disconnected the engine harnesses while I was at Sears grabbing a 32mm socket
Looking at the passengers side intake manifold. Can someone give me some info on which ones I will need to loosen to release the fuel pressure?
A look at the drivers side. Again what hoses should I disconnect here:
Another shot a little backed out showing the fuel rail:
Just need to get the necessary lines / hoses seperated so I can pull this motor.
Not going to be using A/C with the GSR so all lines can go!
Thanks!
Thanks!
Bodman
11
Aug 19, 2003 06:14 PM
Fuster_Cluck
Mar 5, 2003 07:54 AM
Fuster_Cluck
13
Jan 13, 2003 04:17 AM
