how can i take off and replace my TPS , its riveted?
Old Mar 5, 2003 | 06:16 AM
civicracer1993's Avatar
Default how can i take off and replace my TPS , its riveted?
how can i get it off and put a new one that works? its a 91 intake mani and tb (si))
Old Mar 5, 2003 | 06:45 AM
PhatOptimo's Avatar
Default Re: how can i take off and replace my TPS , its riveted? (civicracer1993)
Most people use a dremmel with a cutting wheel attachment. Then they cut into the rivet an make it so it can be removed with a flathead screwdriver. I use a driil bit and drill the heads off the rivets. then the sensor will pop off. If you drill the heads off make sure you have replacement screws.
Old Mar 5, 2003 | 06:53 AM
civictypenos's Avatar
i use the dremel method,just make a slot in it to make it look like a flathead screw,then unscrew it with a screwdriver,then i found some replacement hex head screws so i could adjust it in the car with a allen wrench.remeber to recalibrate it using a voltmeter.
Old Mar 5, 2003 | 08:55 AM
B16b2b's Avatar
Default Re: how can i take off and replace my TPS , its riveted? (civictypenos)
your car will not idle correctly if you don't do this!!!
Old Mar 5, 2003 | 09:05 AM
Tony Starks's Avatar
Default Re: how can i take off and replace my TPS , its riveted? (B16b2b)
If you don't have a dremel, be VERY CAREFUL with a hack saw and cut the bolts.
Old Mar 5, 2003 | 04:08 PM
scdarksol's Avatar
how do you recalibrate it?
Old Mar 5, 2003 | 04:18 PM
PhatOptimo's Avatar
Default Re: how can i take off and replace my TPS , its riveted? (scdarksol)
read my post in this thread.
https://honda-tech.com/zerothread?id=376620
cehcivic15
Aug 14, 2009 01:56 AM
Nuke209
Dec 13, 2005 05:25 PM
aaj23
Jan 31, 2005 10:45 PM
Batoutahell
Aug 15, 2003 07:39 AM
roc109
Nov 29, 2002 07:25 AM
