The beast is ALIVE!!! Almost done (vids and pics) no 56'ers
Old Mar 5, 2003 | 04:19 AM
MiraiZ's Avatar
Default The beast is ALIVE!!! Almost done (vids and pics) no 56'ers
Hi y'all,
This is my weekly progress report on my turbo R rebuild! I got a call tonight from Koyama Garage. "wanna see your engine in action" a voice says over the line.
I leaped to my feet (quite literally) and yelled, "hell yeah!"
"We got it all hooked up to the engine dyno and were just about to start her up, stop by if you got time"
If I got time? Hell, the fifteen minute walk to the garage only took 6 minutes.
"Wow! damn you're fast" he said...
"Oh yeah!...I move quick on stuff like this..."
I navigated my way through the garage. By now, I knew my way around pretty well.
On my immediate right I see a guy working on an old school Lotus Race car:
It look amazing, but my attention span was short because all I had on my mind was seeing my B18c in action on the engine dyno (pictured below).
It was amazing! The now Endyne/eagle powered B18cR started up effortlessly and hummed like sleeping kitten. The garaged had their own in house standalone ECU which they control from a control room with a Sony Vaio laptop. I watched as the technician made adjustments to the fuel and timimg maps as well as about a hundred different other parameter. With each changed, the engine changed its tone. The throttle, fuel pressure, oil pressure, and water pressure along with several other settings was controlled with a very complicated looking control panel.
After about 2000rpms, the engine stated to smoke pretty badley. I was concerned at first, but then mechanic smiled at me and said "uh...I thing we are gonna have to cut that oil soaked header wrap off of your downpipe. I hae never felt so relieved in my life....
They stopped the engine and unbolted the oil soaked DP and header wrap (the oil was from the blown pistons in my last setup.)
When they pulled the wrap off the dp actually fell apart at the seams. What had happed was, the exhaust got so hot, it actually melted the welds on my custom DP. (it was a quick but shotty weld job)...and the wrap was actually holding it together . The took the now 2 piece dp to the back and did a proper weld job.
After about 20 minutes...everything was back for another run....this time a smokeless and perfect pull to a steady 2500rpms. water temp held at 78 degrees celcius (only 3 degrees hotter than stock)...couldn't tell what the turbo was boosting becase the didn't have a boost gauge hooked up. They ran the engine for 30 minutes and it purred flawlessly all the way through. They will do more test and break the engine through the weekend and it goes back in the R next week!! Happy happy joy joy!!!
Videos:
not too exciting or eventful but since I took them...have a look!
1st run...(smoking like crazy )
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
2nd run (still smoking) but you get a good look at the turbo anf the dyno:
Perfect run (no smoke):
that's all for now!
Old Mar 5, 2003 | 04:35 AM
boostin GSR's Avatar
Default Re: The beast is ALIVE!!! Almost done (vids and pics) no 56'ers (MiraiZ)
nice car man, hope everything breaks in properly and runs well.
-in the laptop photo, is that program part of the power fc? i was thinking about getting one of those to control everything for my car, the power fc work well for u?
again, nice ride
Old Mar 5, 2003 | 04:44 AM
Hammett's Avatar
Default Re: The beast is ALIVE!!! Almost done (BoostinGSR)
glad youre happy..
[Modified by Hammett, 5:45 AM 3/5/2003]
Old Mar 5, 2003 | 04:50 AM
MiraiZ's Avatar
no its not the datalogic...this is an inhouse ECU made and programmed by this garage...they're pretty amazing!...It geared to get an idea of what the best running envronment is for the engine (similar to the autotune function of the Hondata and AEM EMS), then the technician makes fine adjustments.
The FC is good, but I need to get it tune which will be my next quest...looking for some FC tuners now..
Old Mar 5, 2003 | 05:53 AM
ProEater's Avatar
Default Re: The beast is ALIVE!!! Almost done (MiraiZ)
nice vids
Old Mar 5, 2003 | 05:58 AM
lsvtec101's Avatar
Default Re: The beast is ALIVE!!! Almost done (ProEater)
why didnt u rev that bad boy up
Old Mar 5, 2003 | 07:15 AM
Baltz's Avatar
Default Re: The beast is ALIVE!!! Almost done (aemcivic_02917)
motor break in
Old Mar 5, 2003 | 07:58 AM
GruvyTune's Avatar
New User
miraiZ,
so, did you have them put your oil return in your block rather than the oil pan?
someone was telling me that having the hot foamy oil running in above the level of the windage tray would cause potential problems. just wondering because I was considering doing that
Old Mar 5, 2003 | 09:17 AM
Slick GS-R's Avatar
Default Re: The beast is ALIVE!!! Almost done (GruvyTune)
miraiZ,
what he said
Old Mar 5, 2003 | 10:28 AM
AB16A2T's Avatar
Default Re: The beast is ALIVE!!! Almost done (Slick_GS-R)
Very nice.
Old Mar 5, 2003 | 10:35 AM
done's Avatar
when breaking in a motor is done without the turbo on.. i thought you break it in allmotor
Old Mar 5, 2003 | 11:46 AM
MiraiZ's Avatar
miraiZ,
I looked at the return setup and it they had put it back to the pan again...I asked a bout the block and they said that the position of the turbo was so low that the pan might be better. But they did do the return better for me so that is more secure.
Turbo breakin vs. NA breakin...it doesn matter as long as I don't get crazy with the boost. On the engine dyno, the engine was barely under boost because it was at 2500rpms or lower the whole time.
Old Mar 5, 2003 | 01:31 PM
MiraiZ's Avatar
Besides the break in, the reason why we didn't rev the engine any higher then we did was because the computer that they have, takes about 10 to 15 minutes to autotune every 500rpm increment. So just to be able to get it to rev up to 2500, took about an hour of tuning. The rest of the map would take a few days to do, which is pointless, because I won't be using their ECU (couldn't even if I wanted to)...they just wanted to get it tuned enough just to test it and do some benchmarking...and fix any problems that may come up...the REAL tuning will come in play once the engine is in the car.
Old Mar 5, 2003 | 04:23 PM
SiRkid's Avatar
Old Mar 5, 2003 | 04:34 PM
GZERO's Avatar
Can't you copy the values off their tables and plug them in your tables (if hondata or EMS, etc..)???
Old Mar 5, 2003 | 05:09 PM
MiraiZ's Avatar
Default Re: The beast is ALIVE!!! Almost done (GZERO)
I wish it was as easy as that...but these values reflect what the engine is doing out of the car, and no tranny or gear box hooked up...not going to do any any good even if i could do it. The car will need to be tuned on a chassis dyno to ensure the most accurate tune.
Old Mar 17, 2003 | 02:58 AM
Chaze*R's Avatar
Do you have pictures of the car? I was in the ITR forum, but wasn't there in time to see the pictures of your car. BTW, good luck with the break in.
Old Mar 17, 2003 | 03:13 AM
MiraiZ's Avatar
Default Re: The beast is ALIVE!!! Almost done (Chaze*R)
This is a picture that someone criticized in the ITR forum. It was taken the night she came back. Its been raining so haven't been able to take any more...maybe this weekend..
Old Mar 17, 2003 | 03:36 AM
mycivicstoo(s)low's Avatar
Why did somebody critize that? It's beautiful!
Old Mar 17, 2003 | 03:47 AM
MiraiZ's Avatar
Default Re: The beast is ALIVE!!! Almost done (mycivicstooslow)
beats me...asking the same questions...damn **** haters in the ITR forum. If it doesn't look exactly like their cars ...then it must be rice , I guess
Old Mar 17, 2003 | 03:53 AM
They're probably just jealous. I'm sure it doesn't bother you in the least. Keep us posted.
Old Mar 17, 2003 | 06:37 PM
Chaze*R's Avatar
Nice car! FMIC looks so good...scary even. hehe. Nice lot number(8) too...in Chinese culture the number 8 is symbolic with fortune.
Old Mar 17, 2003 | 07:08 PM
SiRkid's Avatar
that car is so sweet.
and the black housings with hid..drooooooooooool.
Old Mar 17, 2003 | 07:19 PM
wHOAlly's Avatar
yet another reason i hate most ITR owners
Old Mar 17, 2003 | 09:07 PM
ModlesSI's Avatar
New User
Default Re: The beast is ALIVE!!! Almost done (There is no sp00n!)
Awesome car! Damn haters ... give him a wash when hes back on his feet though, haha.
smutmonger
Sep 29, 2005 06:58 PM
Synthead
Mar 2, 2005 09:53 PM
Hunter
10
Aug 24, 2003 08:42 PM
