battery light on in a 94 civic coupe with a b18c1/obd1-p72 ecu
Old Mar 4, 2003 | 08:41 PM
Turbo(less)DB8's Avatar
Default battery light on in a 94 civic coupe with a b18c1/obd1-p72 ecu
I was driving around today and my battery light came on. The car still ran fine. Nothing wierd was happening. I charged my battery for 24 hours and it's still on. Help!
Old Mar 5, 2003 | 05:23 AM
JimBlake's Avatar
Default Re: battery light on in a 94 civic coupe with a b18c1/obd1-p72 ecu (nscivic)
That's telling you your charging system isn't working, not the battery itself. Your car will run off of the battery for a little while, its just not getting charged back up as you drive, like it should.
Look for loose wiring at your alternator, corroded ground wires, stuff like that. Then have the alternator checked out. Maybe voltage regulator, of if you're lucky just worn-out brushes.
Old Mar 5, 2003 | 05:38 AM
94TealGSR's Avatar
Yeah, check your alternator belt... make sure it's turning when the car is on. If that's not it, take your alternator out and have it checked.
Old Mar 5, 2003 | 05:25 PM
Default Re: battery light on in a 94 civic coupe with a b18c1/obd1-p72 ecu (94TealGSR)
Um... yeah i'm a dumbass . I checked under the hood and sure enough the alt belt was gone. Anyway, got a new one put one. Thanks.
89edcivic
Sep 26, 2009 02:38 PM
haywyre
Oct 9, 2008 12:27 PM
cougar82
Aug 29, 2004 04:12 AM
SilverSellout
16
Nov 6, 2003 08:47 AM
fe519
Sep 23, 2003 03:25 AM
