JE 11.5:1 cr pistons...
Old Mar 4, 2003 | 08:09 PM
laughinxxx's Avatar
New User
Default JE 11.5:1 cr pistons...
Can anyone think of a reason not to drop these into a sleeved H22 block? Don't worry about me running nitrous on it. I'll hook up a fuel cell for 100 octane if I can't get it to run on the bottle and 93 octane at the same time.
Old Mar 5, 2003 | 05:09 AM
laughinxxx's Avatar
New User
Default Re: JE 11.5:1 cr pistons... (laughinxxx)
I guess no answer is a good answer.
Old Mar 5, 2003 | 06:09 AM
LudeyKrus's Avatar
Just from what I've heard when I was contemplatin H22 pistons into H23....
11.1 you can spray, but be careful. Most people recommended not to spray over a 75 shot, to be safe. 11.5 I know you COULD spray, but noone was recommending it w/o careful tuning, and I'm guessin the shot would need to start small. That's all I know!
Old Mar 5, 2003 | 06:41 AM
743's Avatar
743
Default Re: JE 11.5:1 cr pistons... (LudeyKrus)
i used to have 11.5:1 compression SRP's (JE shelf piston) in my ls/vtec. The quality was good and they were nice pistons. But at the time i didnt know that totalseal rings and JE pistons didnt get along well. A peice of the totalseal broke off into the combustion chamber and completely raped my engine. I never really had a chance to fully enjoy the motor, but i say to go for the pistons... i just recommend staying away from totalseal rings.
Old Mar 5, 2003 | 07:55 AM
Finest's Avatar
Nitrous loves compression.
But remember that your tuning window is that much smaller. What do you have in terms of fuel/ignition mods?
And is this on stock rods? In the situation that you encounter severe detonation, the pistons might survive...but those rods can bend.
Go for it...but just be VERY careful on the tuning. You do have an assortment of gauges to monitor your engine, correct?
Old Mar 5, 2003 | 09:27 AM
laughinxxx's Avatar
New User
Default Re: JE 11.5:1 cr pistons... (98CTRCoupe)
Why are yall telling me to run a small shot on a high compression motor and that my tuning window will be small? I know that already. Besides I have no problem running two fuel systems if necessary.
What I am concerned about is the piston dome and the valves skullfucking each other and whether or not it will detonate itself to hell on 93 octane.
Yes, forged rods will be used.
Thanks for the tip about the total seal rings.
Edit: No gauges as of yet. I am just starting to plan my build up. I'll have run out of things to modify on my car after this spring, so I'll be picking up a new motor when money becomes available again.
[Modified by laughinxxx, 10:30 AM 3/5/2003]
Old Mar 5, 2003 | 11:49 AM
Boostless97Lude
Guest
Posts: n/a
ok, apparently Wiseco is the only one making forged pistons that you do not have to re-sleeve, HOWEVER, JE pistons do require re-sleeving
i'll go easy on you this time laughinxxx, but, *cough*this is one of those type of questions that has been covered*cough*
Old Mar 5, 2003 | 11:55 AM
satan_srv's Avatar
Default Re: JE 11.5:1 cr pistons... (Busted97Lude)
what's the bore on these pistons?
Old Mar 5, 2003 | 12:04 PM
Furry
Guest
Posts: n/a
Default Re: JE 11.5:1 cr pistons... (satan_srv)
stock or 0.25mm over i believe is what the wiesco pistons are. 9:1 and 11 or 11.5:1 are the only off the shelf cr's the offer
Old Mar 5, 2003 | 12:13 PM
laughinxxx's Avatar
New User
Satan, 87.0 mm.
I did a search and wasn't happy with the information that I received.
Old Mar 5, 2003 | 12:19 PM
Boostless97Lude
Guest
Posts: n/a
hahaha... lol, although mostly the search function won't pick up the good discussion b/c the people didn't title there posts like the should have
Old Mar 5, 2003 | 12:24 PM
satan_srv's Avatar
I ran Custom Arias 11.5:1 pistons for the H23 VTEC...
tuned on 94 octane. What specifically are you looking for here? I wasn't spraying so I can't add to that discussion unfortunately
Old Mar 5, 2003 | 01:14 PM
Boostless97Lude
Guest
Posts: n/a
laughinxxx: i have a friend looking to sell his Saturn and buy a 91 model Accord and H22 swap. anyways, he likes nitrous, and wants to spray the H22, he called me a few minutes ago and asked me how big of a shot eh could use safely, i told him that i was pretty sure you were running over a 100 shot on you stock engine... correct me if i am wrong, but please, some good infor on you previous/current setup would be nice.
Old Mar 5, 2003 | 01:44 PM
laughinxxx's Avatar
New User
I just want to make sure that I'm not forgetting anything when I plan on running 11.5:1 pistons on pump gas. If you have any cam suggestions I'd welcome the suggestions.
I'm not spraying a 100 shot yet. If he wants to send me a Walboro 255 in tank fuel pump I'll test it out for him, because I know it will hold at least a 100 shot.
Old Mar 5, 2003 | 01:49 PM
Finest's Avatar
Thank you for disclosing all of that info AFTER your ambiguous title and first post.
It looks like you have everything figured out. If you don't know if there will be valve/piston contact...I think you should contact the piston manufacturer for their specifications concerning valve reliefs and such. 11.5:1 CR probably wouldn't have a high enough dome to bring up such concerns. BUT, for peace of mind, you can clay the piston for clearances. (Labor intensive, but atleast you'll be CERTAIN)
And yes, you can run this on 93 octane...nothing less.
Old Mar 5, 2003 | 03:00 PM
satan_srv's Avatar
Basically what he said. If JE makes an 11.5:1 off the shelf piston and you have not milled your head, and your valves are stock, you shouldn't have any issues. Fuel tuning is important, but I know a lot of people running type-s pistons + milled head with no fuel tuningon 94 and they seem to be fine..
Old Mar 5, 2003 | 05:53 PM
laughinxxx's Avatar
New User
Well the S100 should take care of the fuel tuning. Thanks for the help.
Old Mar 5, 2003 | 07:55 PM
fastludeh22's Avatar
why not go all out, i have some 90 mm 12:1 endyne/wiesco pistons i need to sell. im me and we'll work out a good price.
Old Mar 5, 2003 | 09:03 PM
laughinxxx's Avatar
New User
Default Re: JE 11.5:1 cr pistons... (fastludeh22)
I would but I'm finishing getting the S100 and some other toys into the car still.
Old Mar 6, 2003 | 12:01 PM
NXLude's Avatar
Id stay with a 11 to 1 piston, you got such a nice bottle setuop why waste it......leave it so you can spray a 100 shot or do your dual stage thingy....besides, 11:1 is just fine for all motor too......
DC-4-Drew
Jul 25, 2005 08:30 PM
EM2Civic
Feb 27, 2005 05:01 PM
Rick Solis
Apr 16, 2004 11:53 PM
jackedcrew
Mar 28, 2004 07:44 PM
96tegsr
Nov 8, 2001 02:38 PM
