My trunk won't open!?!?!?
Old Mar 4, 2003 | 06:59 PM
stoopid215's Avatar
Default My trunk won't open!?!?!?
I have a 5th gen... and apparently the strangest thing happened today. I couldn't open my trunk using my key, however it will open when i use the latch inside the car. The key turns, but when i checked the mechanism on the opposite side of the trunk, there is this loose piece of plastic not connected to anything. Therefore when i turn the key, nothing happens. Is there supposed to be some type of chord/cable that is attached to this plastic which causes the trunk to open when i turn the key?? Something missing here?
Old Mar 4, 2003 | 07:47 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: My trunk won't open!?!?!? (stoopid215)
if it is the piece i am thinking of, there should be a small rod type thing that is connected the the whit piece.... i am not exactly sure, but if i can remember, i will look at my trunk mechanism sometime tomorrow and let you know
Old Mar 4, 2003 | 09:50 PM
stoopid215's Avatar
Default Re: My trunk won't open!?!?!? (Busted97Lude)
yeah that little piece is grey and its like a lever...but its not attached to anything? where did that rod thingy go?!?! i searched my trunk and nothing?!?! ill take a picture of it tommorow.
Old Mar 4, 2003 | 10:01 PM
stoopid215's Avatar
NM PRObLEM IS FIXED , i dug around and saw the rod stuck in the trunk.. attached it ... now it works
Old Mar 4, 2003 | 10:44 PM
DsITR's Avatar
heh..
You need to quit taking hairpins @mach II yO!
Old Mar 5, 2003 | 06:46 AM
rjr162's Avatar
Default Re: My trunk won't open!?!?!? (dsludefosho)
wow! i thought I was the only one that hit this prob. I was trying to put down my back seat to take it out.. and it wouldn't unlatch! Damn that hooked S thingy design!
griff12
Jul 25, 2013 06:39 AM
xx69xx
Honda Civic (2001 - 2005)
Jul 22, 2010 04:18 PM
norcal450
Honda Civic (2006 - 2015)
12
May 2, 2007 09:53 AM
GuCCi_GSR
Sep 10, 2005 12:43 AM
Flamenco-T
Oct 16, 2002 10:36 AM
