what year prelude intake manifold will fit a 95 accord?????????????????????
i want a larger intake manifold and i was told that a prelude manifold would do the trick cause it is a direct replacement. but which year and model will fir a 95 lx????
I didn't think the intake manifolds where interchangable.
Are you looking for an after-market manifold or the orginal stock one?
The person that told you that may have ment the 4th gen f22 preludes, which is the same motor, so that won't do you any good.
I don't think there's any options on intake manifolds for f22's.
the H series Intake Manifolds use the same gasket as far as I know
they are supposed to be interchangeable
yea. check a junkyard near you for a sotck lude one, if it fits use it till you can find a good aftermarket one. it it doesnt work sell it to somone.
From Experience:
H23a1 intake manifold on an F22b2 requires some port matching on the F22b2 head, use an H23a1 gasket, everything is golden once the ports are matched.
