crx 1989 suspension swap
Old Mar 4, 2003 | 04:47 PM
turbod16y7vtec's Avatar
Default crx 1989 suspension swap
could the suspension of a 1991 integra fit in a crx
Old Mar 4, 2003 | 07:13 PM
FullMetalJacket's Avatar
Default Re: crx 1989 suspension swap (turbod16y7vtec)
yeh but ur camber will be off a lot
Old Mar 4, 2003 | 07:21 PM
just need a camber kit right
Old Mar 4, 2003 | 07:26 PM
JDMBOLONI's Avatar
the camber will be off??? i replaced all my tie rods when i put the DA 90-93 teg nuckles on and eyed the alignment and the tires wear perfect. the springs and struts shouldn't have any outcome on the allignment with this swap but im only 99.5% sure
ghettocrxsi's Avatar
you camber will not be off at ******* all... why do people go by all this hear say bull ****.. Many times we have put 90-93 integra full disc on 88-91 hatches and crx's with out! any camber problems at al.. make sure you use the brakes lines from the integra along with the master cylinder and proportioning valve
Old Mar 4, 2003 | 07:44 PM
FAUCON's Avatar
My camber was ok too when I put the 93 front knuckle.
Old Mar 4, 2003 | 07:48 PM
Default Re: crx 1989 suspension swap (FAUCON)
It would be toe if anything.. but they are basically the same knuckles but different calipers and bigger hubs.. he is thinking about 94+ Integra suspention.. that gives you bad toe.. and camber which can be corrected by a camber kit and an alignment
Old Mar 4, 2003 | 08:01 PM
Ben Ogle's Avatar
Default Re: crx 1989 suspension swap (ghettocrxsi)
I had 93 teg knuckles on my 88 and I got a little + camber and a lot of toe out. Also, I couldnt get rid of the bump steer so I switched back to the stock ones untill I find some EX knuckles.
Ben
hatmanafro
Jan 13, 2011 11:24 AM
LumpyCRX
11
Nov 20, 2007 09:10 AM
Steve91
16
Oct 23, 2002 12:09 PM
paulzy
Dec 19, 2001 09:33 PM
