Apexi Power FC with GM 3 bar map and commander
I jsut got my AEM and 3.5 bar map so im parting with my old standalone. I had it for 2 years and it worked flawless and never had a problem. The program i used it still in it or you can initialize it and have a stock ctr program. Included is a 3 bar GM map sensor and the commander for the unit so you can change nearly anything. This is able to run 1000cc injectors and turn off the secondary o2 sensor. Also you can alter vtec engagement and idle speed and rev limit to anything you want. You can also change the ignition tables. The best i can describe it is that its almost identical to DFI. It uses the same random figues and such. Gotta see if any of you guys want it before it hits Ebay.
700 shipped FIRM
Guess i should tell you want it fits. It will work with OBD2 only
[Modified by boosted3g, 7:01 PM 3/4/2003]
700 shipped FIRM
Thank God 4 Vtec
Jun 26, 2008 09:40 PM
